Faceplate stuck...Help!
Palm Harbor, Florida
I have an Easy Wood (aluminum?) 4-1/2" faceplate stuck to my spindle. The set screws were tightened, but have now been loosened. There is a 1/4" hole about 1/2" deep on the edge of the faceplate but I don't have anything of that size to try to leverage the faceplate off. Any suggestions/help would be greatly appreciated..
Buy a strap wrench big enough to go around the bowl. You might try a pipe clamp across the rim of the bowl, and one the hub of the faceplate. Then rap the pipe with a mallet. Impact force works better than a steady force.
The pipe wrench worked! Thanks, all, for the help. Now back to making shavings.
You might get a spanner wrench
I always snug faceplates and chucks on with a solid push.
That way the come off with an equally solid pull.
A spanner wrench should fit the hole and make snugging and releasing easy
Now that you have it off...get a metal rod that will fit the hole. Next time, insert the rod and apply a 'dead blow' hammer with a sharp whack. Oh...and get a nylon washer spacer for the next time.
I have made several rings from milk, soap or similar plastic containers. Put one on and never need the other ones I made at same time. I used a circle cutter, but two different size hole saw should also work to be fancy. Don't think they need to be perfect circles.
There are lots of ways to cut circles.
Most of us have machine designed to cut circles. :-)
You can cut them on the lathe with skew point down.
Face off some scrap wood stack your plastic. Pin it to the wood with the tail center
Mark the 2 diameters. Cut the outside cut the inside you then have as many washers as you stacked up.
