I have a nice 6x15" diameter Ash bowl that's been roughed and seasoned to stabilization. It has in the wall a rather large bark inclusion that goes all the way through, and is present on both sides of the wall.
In the past, I've had good results with adding epoxy to small voids, but this one is intimidating.
For past application, I've turned to very near final wall thickness, applied epoxy, and turned/sanded as per usual......worked pretty well, but it was an obvious fix. I used clear epoxy, and it really wasn't all that bad looking. I've found the clear epoxy to sand fairly well, having a dull sheen to it's final sanded preparation.
To fill this Ash bowl, it looks like it will take quite a lot of epoxy to do the job. More than one application may be necessary to completely fill in the void. First question for those who have attempted this: Will more than one application of epoxy make the fix even more obvious.....or, will the "seam" between applications be a big problem? At the moment, I only intend to fill in the interior void, and leave the outside in a natural state. My intentions are for a salad bowl.
If there are any other methods I should be aware of, please respond.....but, it has to look good in result. Filling the void and trying to match the color with a sawdust and glue mud, in my opinion, looks worse than the clear epoxy.
If you need a photo to advise me on this, that can be done, but there is nothing really radically different with this bark inclusion over what you all have seen before........just that it will require a larger than average amount of epoxy to fill the void. If you have a photo of a completed bowl that has a filled void, I'd appreciate your effort to show us that........
Once again, I thank you for your input to my constant questioning. :cool2:
