- Joined
- Jan 27, 2005
- Messages
- 13,223
- Likes
- 5,851
- Location
- Dalworthington Gardens, TX
- Website
- pbase.com
The point about it taking a few days to fully harden... So do you wait until then until you do any sanding at all? Or do you sand between every couple of coats? I was sanding between every 2 coats of lacquer on the items I've lacquered so far, but, I wonder if that is problematic if the finish hasn't fully dried yet.
Yes, I generally don't sand until all the coats have been applied. An exception would be if there is a problem such as really bad orange peel, but I still would give the finish sufficient time to dry. How long is "long enough" depends on how heavy the coats are and the weather.
Unlike varnish that has gone past the no-sand recoat window, lacquer usually doesn't need to be sanded between coats. One of the problems with sanding lacquer too soon is "burning through" the finish (sanding through the finish to bare wood). Since I spray outdoors, the biggest problem for me is that gnats just love to land on a wet finish. When that happens I let the finish dry for a few hours and then use a paper towel to knock down the bugs and dust nibs.
I sometimes use crosslinking catalyzed lacquer. It is treated more like varnish when it comes to sanding.
