This is my first bowl in over 15-years and I'm thinking the finish "just ain't right".
My direction has been large hollow-forms which have some things in common:
- Large pieces come from large logs which have an abundance of imperfections: piths, knots, checks/cracks, bark inclusions, bores, musket-balls, etc. - even rocks in root-ball.
- Learned early on that you can't turn past the problem. The choice is lot's of firewood or embrace the defect.
- An anomaly or feature differs from the surrounding grain and becomes an opening to be filled with a different material with a very different texture (epoxy, putty, etc.) - for me, leaving "worm-dirt" is not an option.
- There are limitations: it's both difficult and unattractive, as well as problematic, to fill a large span - sometimes better to create an opening
- The beauty of a barrier/sealer/clearcoat/rubbed finish is that the anomalies "largely" go away - those that stand-out add to the piece
- The problem of a barrier/sealer/clearcoat/rubbed finish is it doesn't look that great on "functional" pieces - imagine your chest-of-drawers, dining table, and furniture with a show-car finish - in my mind, same with wood bowls
