First large (for me) bowl
Gurnee, IL
Hi all,
I am getting ready to start my largest bowl (mostly I’ve done 6-7 inch bowls). I have a 12/16 Laguna lathe. My blank is a 10x3 piece of Macacauba. I’ll cut it round before I start. I have a new Vicmarc chuck with 100mm jaws.
My questions are:
1. For initial roughing and shaping should I turn between centers, or use the worm screw?
2. Tenon or recess to mount to the chuck for turning the rest of the bowl.
The shape I’m aiming for is flying saucer. 2/3 convex curve at the bottom, and a 1/3 convex curve on top. Then a concave recess in the top for the bowl part that’s about 1/3 of the bowl radius.
I’m a bit nervous turning something with that much mass, but I have pretty good spidey senses when something seems off.
Thanks for any experienced input I can get. This is for a charity silent auction and I have plenty of time to complete.
Here is a photo example of what I’m going for:
If it’s your largest bowl and you are unsure, use screw. If comfortable turning, quicker between centers and retain ability to adjust blank to best position. As for tenon or recess (mortise), whatever you are comfortable with, but if you make a recess, don’t go deep (less than 1/4 inch), leave wood around it, and remember when turning the bowl that you have a recess so you don’t funnel it!
I also have a Laguna 12/16. I turn 12" bowls frequently. I always use a wood screw. I bring the tail stock up for the initial outside shaping. I always turn a tenon. For a 12", I usually turn a 4" tenon (less than 1/4" deep - maybe closer to 1/8") that becomes the final foot. I completely finish the outside before turning around to do the inside. For that size, I have to set the belt to the lowest setting to get the most torque. That limits the highest speed to mid-500's. Final cuts need to go slow with minimal shavings. Good luck!
In all honesty, these are personal preferences, and there are pros and cons to each. No absolute answer for "should I".
My personal preference is to start things between centers because 1) it's just easier and quicker for me, and 2) I can adjust the orientation. Between centers I can eliminate or highlight figure/voids/etc, balance grain patterns, or even change my mind about which is the top/bottom. With a screw, you lock yourself in once that hole is drilled.
But a worm screw in the right size hole, especially when backed up with the tailstock, is probably more secure in most cases. So if you're more confident that way, use the screw.
And for the bottom, I personally prefer tenons - mainly because they're easier to make when the tailstock is there. I also have more confidence in their holding power (maybe that's all in my head). But a recess might be the only way to go if you're short on wood and the recess needs to become part of the foot design. But you can also use wood inside a larger tenon for the base.
If you decide on a recess, remember the jaws are pushing out on the wood so leave enough "meat" there outside the recess for the jaws to push on.
Agree with Dave that these choices will vary depending on who you ask. I prefer to use a tenon over a mortise, especially if you’re a newer turner. Gives you a little insurance; if you go too deep, the tenon becomes a foot and you avoid a funnel.
Never heard of that wood species. Nothing wrong with gluing up a blank of the same size using poplar and turn as intended. You may decide to change the design, before starting on the intended wood. Make sure your intended blank is completely dry before starting, not coated with wax and wet.. My 2 cents.
I've heard of weird things with the woodworm screws. I have a couple that came with my chicks, but I rarely use them. If the hole isn't perpendicular to the face of the blank, it can put lateral stress on it. (seen a couple photos of broken off screws) Also, if you get into roughing out the blank and have some kind of hidden defect or spectacular figure? Now you have a big hole deep into your blank dictating which side is up, no going back. (you're screwed 🤪)
A mortise or recess should work as well as a tenon, but the tenon allows you to see where your chuck ends.
I wish you the best of luck with it. It sounds like beautiful wood, but to be honest, I feel like you'd do better to put it aside and use a less expensive more common wood for your first bowls. Someday when you've done a bunch of bowls and can confidently turn a nice shape with no tool marks or tearout, then pull that out and make a trophy piece.
Agree with everyone else, your questions are personal preference, not yes/no.
I prefer starting between centers and using a tenon, same reasons others stated. Also agree that you should set this blank aside and choose a cheap/free chunk or glue something up for a 1st and 2nd attempt at something. Anytime I try something new I do it 2-3 times with “boring wood” to work out the process and overcome any reservations I have with the process.
If that blank is sealed it is probably not dry. Several choices available of how to proceed, depending on how “true” you want the finished piece to be.
As said, it's up to you. Personally, I'd use screw AND tail stock. I would also be inclined to use a recess for this design. I think it will look better sitting flat on a shelf than on a foot--but you could remove the tenon at the end.
I suspect this design will crack if the wood is not dry as the "walls" are very thick. If you have a lumber yard near by you may be able to get some 12/4 kiln dried hardwood in a wide width. (I think this design would look good in cherry.) You might also find some poplar for prototypes.
Me, I would make some full size cross-sectional drawings to try out some variations of the design.
A drawing also helps me think about and plan the process I'm going to use. For example you may turn the outside and base first, then remount on a tenon/recess and form the basin. Next would be to reverse the mount again to finsh off the base. But how to do that final workhold? A vacuum chuck would be my first choice. Cole jaws/ Longworth, with extra tall buttons, might work. Jam chuck with double stick tape??
If you use a recess you might be able to skip, or at least minimize processing the base.
Just my thoughts.
When I teach beginners bowl turning
I always start them with a round disc about 10” diameter and 3-4” thick with a hole drilled for a worm screw.
Fewer things to learn for this.
Mounting instructions - lock the spindle and screw the blank onto the worm screw tightly.
The second bowl they do between centers. Need to cover alignment. Keeping the tailstock tight - tighten periodically
Then during the roughing fine tune the grain alignment,
Working around the tail center when forming the tenon…..
Probably be good to follow a similar practice when teaching yourself
When I'm turning a larger piece, I tend to turn between centers to start. I will flatten both faces then remove/examine the grain and other features. From there, I decide how to make a bowl/platter to highlight it the best. Sometimes I decide to hit the band-saw and cut out one, 2 or 3 bowls/platters/cups, etc. From one blank, I can get a nice shape like your picture albeit smaller leaving a couple pieces of the blank for practice or design ideas first. Depends on blank size in the end.
I agree with those who recommend you mount a piece of wood you don't care about for your first larger bowl, or two, especially since you're going for a challenging design. You'll learn a lot, and the final piece will be much better for it.
I guess I'm odd man out. I like a faceplate and use length of screws as needed. Even my 12 inch diameter x 2 inch thick blanks I'll stick a faceplate on..
