Thanks to JimLee for starting his thread on sanding. I read it, but probably still got impatient. Hand-sanding at this point (no drill). Started at 100 grit because there was a "rise" in inside of the bowl just under the lower part of the rim that I decided to use Abranet on rather than risk the scraper so close to the edge. In the process, noticed that the bowl might well have moved, even though the wood was ever-so-dry (bowl stayed chuck after coming off Mr. Mentor's lathe on Wednesday). Didn't seem completely symmetrical. Anyway, used 100, then 150, then 180. Looking at the bowl now, appears I need to go back to 150. Here are pictures. There are color differences I assume I still need to even out. Also, see comments above the picture of end-grain on the outside. [Reed, I didn't see your video until afterward
Face grain inside, looks pretty OK
End-grain needs work, so go back to 150? or further? (I don't have any 120 in stock, but can buy tomorrow).
(Please ignore the bottom, rim is where I worked the most). Face grain again pretty OK
Oh, dear, end grain really needs work, so back to lower grit on outside too! Any comments on the open pores??
