Well I broke down and ordered a McNaughton standard system a couple weeks ago from LV. When it arrived the tool rest post was missing. Joy. Had LV send me a post which arrived mid week last week and I finally had a chance to try the thing out on Sunday. Jet 1642, 1 1/2 hp version, Talon chuck with #3 jaws, 11" diameter by 7" thick black walnut blank. Blank has been on the shelf, Anchor Sealed for a couple months so it wasn't sloppy wet.
I was successful. I did manage to stall the lathe about three times though, had the blank pop out of the chuck twice, once tearing up the tenon. CA glued the tenon back together and finished it up. Waste ejection seemed to be the biggest problem. I think one of the stalls was caused by a log jam of shavings. Is that typical or was this just ornery walnut?
When I was done and cleaning up I discovered that the set screw that holds the tool rest assembly together had worked itself out. Found it amongst the shavings. Yikes! I'm surprised the assembly held together under all that stress having a screw missing. Like me. Think I'll put a drop of nail polish down that chute to prevent a reoccurrence.
I seemed to have the most trouble achieving a smooth feed of the tool into the work. The blade seems to stick in the gate. Should I lube that with something? Also the blades in my kit are black and on the Kelton website they're all nice and shiny plain steel. The black paint is already coming off the one blade I used. Should I speed that removal?
Looking forward to digging into my stash of Box Elder with this thing next weekend.
