Food safe or non-food safe?
Cleveland, Tennessee
When selling at a show, how do you differentiate between food safe and non-food safe items? My concern is a customer buying a bowl and using it for snacks, etc. when it has a certain finish. TIA.
Since there are so many finishes that fully cured are food safe, I only use food safe finishes for my bowls. I don’t think there is a good way to inform the customer that the bowl is only to be used for non food items.
IMO If it can be used for food or put in the mouth (i.e. it's a bowl, platter, cup, spoon, baby rattle, toy, etc) it should have a food safe finish (or no interior finish). Should also be made from safe material (i.e. wood with low allergy/reaction issues).
Art or display pieces, hollow forms, etc can be from other materials and have other finishes.
Boxes might be in some middle-ground if you think someone might be storing spices, or their "stash", or whatever...
If I can eat it straight out of the can/bottle, then I consider it "food safe". If not, I don't put it on my bowls. "Supposedly" finishes with chemical "driers" are "food safe" after being fully cured. I ran into some one at a show once who was sensitive to those driers and she said that she still reacts to them. I go with the walnut oils. They will cure and harden which mineral oil never does.
I've always approached this from a different perspective, that of the lawsuit. If you're sued applying something not identified as 'food safe' that's on you. If you're sued for a finish that identifies itself as 'food safe', then that's on the manufacturer. Can you still be sued...of course but the lawyers tend to go after those persons with the most money. With so many food safe choices available I'm still befuddled why anyone would choose differently.
Dr. Seri Robinson says...
And...
Here are her three books that may be of interest to you.
Dr. Seri Robinson is a professor in the College of Forestry’s Wood Science and Engineering program, Oregon State University.
A great theoretical discussion but on getting sued for making bowls. I couldn't find any.
My advice is to use what you like. Like what you use. And let it cure completely as per the FDA recommendations for safe food finishes...........
AI Overview
Based on available information and discussions within professional woodturning forums, there are no recorded public lawsuits against individual woodturners for injuries or illnesses resulting from non-food-safe finishes on hand-turned bowls.
While the issue is a frequent topic of debate, the practical risk of a lawsuit for a small-scale turner is considered extremely low, according to discussions on the American Association of Woodturners (AAW) forum.
Key details regarding this topic include:
  • "Food Safe" Misconception: Many experts argue that the concept of "food safe" is often misinterpreted. Most commonly used finishes (lacquer, polyurethane, shellac) are generally considered safe once they have fully cured (hardened), as the volatile solvents evaporate, according to AAW forum members.
  • Liability Concerns: While and individual could technically be liable under negligence or product liability, professional organizations often note that turners have more to worry about regarding injuries from customers falling on their property or displays falling, rather than injuries from food ingestion.
  • Best Practices: Turners are encouraged to use oils like mineral oil, walnut oil, or beeswax for items intended for direct, heavy food use (like salad bowls) to ensure safety and consumer confidence, as noted in a Turnawoodbowl article.
  • The Difference with Epoxy: While some worry about epoxy resin, most manufacturers state that once epoxy is fully cured, it is inert and safe.
    www.aawforum.org +5
While large companies have been sued for importing wood products with toxic chemicals (such as Lumber Liquidators regarding formaldehyde), this does not apply to individual, artisanal woodturners.
