  • Congratulations to Jaramiah Severns for "Stacked Forms II" being selected as Turning of the Week for August 4, 2025 (click here for details)
Foot on bottom 6 " round bowl
This is my "signature" style foot......you are welcome to copy it, if you'd like:
Claro Walnut bowl is 5 3/4" x 2 7/8"
Bowl rests on outside ring of the foot. Everything inside that is recessed below the level of the outside ring.
Sequence is: Outside ring ---> cove ---> Interior flat surface with detail grooves.
Glen my wife pulled out some bowls to put on a shelf in our hallway. They all have slightly diffferent feet and around 6". I'll take a photo in a little while and post them. I don't know if I can find the 2 bowls I did that were exactly the same shape except for the feet. One had a foot and the other was just a concave area. If I find them I'll post that too.
View attachment 24376View attachment 24377
You might be interested to know that Mike Mahoney does something similar on his hollowform urns. The difference is that the outer ring is turned as a bead.
Interesting.......I guess if Mike Mahoney wants to copy my "signature foot", that would be ok with me. :D
Go the Hawaiian way, no foot. We don't call them round bottom calabash for no reason, lol. Lots of my small bowls have no foot, in they vacuum chuck they go, and I take everything off. Aloha
Yes....so boring to have a vessel that sits flat
It is fun turning the round bottom, but it is also very much an experience doing other styles for variety. I usually decide based on the wood and use of the vessel.
I'm working on a big Calabash, almost done, and I did a little cereal bowl today, no foot, just a small indentation, and of course, the calabash, perfectly round.
There are many ways of a foot on the bottom of a turned item from those with a foot to those with out but if you want it to be stable having the concaved centre so that it sits in effect on a ring which keeps it stable and not rock unless you are turning something like Emiliano example above.
You can even go with carving away part of the ring to form small feet which I personally find is best done having three as it will not get any wobble if the bowl moves
In your 1st photo it appears to me this is a crotch piece not split but whole log......if this is correct.....do you Hawaiian often do that so you have a crack to repair.....or because y'all have many bowls 50 & 100 years old there are repaired cracks?????
Both, lol.. it’s a traditional type of calabash, you can see in the ancient ones the 2 branches, just like this one... The local buyer that spends thousands in one of these expects several pewa repairs...
I did not realize about the 2 branches or crotch pieces.....cool
