Frank Sudol deep hollowing rig advice
Marquette, MI
I recently got back into woodturning, after nearly 10 years off to pursue graduate education. Found a 2436 on Craigslist and boom, back into turning. The lathe came with tons of extras including 2 hollowing rigs. One of them seems to be made by Frank Sudol... a large rig made of mostly 1.25” solid steel bar 6’ in length. It also included 2 cutting tools(5/8” OD) that fit this bar and 3 that are larger (3/4”OD) The roller it came with is also pretty heavy duty but the one thing that worries me a bit is that it’s not a CAPTIVE roller. The bar just rests on top of the roller. I’ve searched the Internet pretty deep and can’t find a ton of info on the systems Frank used to use (and I believe sell). Does anyone know anything about this system? Should I modify the roller or buy a new one to make it a captive system or do you think it’s heavy enough (mostly solid bar stock) to use safely without going too deep? Is there another bar that takes the 3/4” tooling that Frank also used/sold?
4D457C90-770C-4C6C-92E1-D48B35506C17.jpeg 4B163A40-BDF0-4963-9E36-4AA6C8154F5E.jpeg EC54FE76-8BB8-41E2-8E24-7CF9D506D485.jpeg
More curious about the system than anything else. Need to get more comfortable with the Jamieson system it came with before I try anything bigger.
Thanks!
I took a class from Frank. We didn't have a captured bar. The bar was so heavy that I don't think it would have kicked up no matter what. When you have the cutter dead center on the turning there isn't really any torque or twisting. I think I turned a 16" deep vessel with his bar.
Think it’s heavy enough (mostly solid bar stock) to use safely without going too deep? Is there another bar that takes the 3/4” tooling that Frank also used/sold?
Thanks!
I don't think you need worry about that massive bar coming up off the roller anytime soon unless you are trying for very deep hollowing, say 16 inches or more, and even then I expect that any catch that would lift the bar would rip the turning off or break it. In any case, you will have your arm over the bar while cutting. Having said that, I notice that the hollowing bits are very broad whereas I almost always use narrow (3/16" ) metal cutting lathe bits for my roughing out work so my gut feeling may be biased. I would suggest that you consider making some new cutters to use these smaller bits.
Oops, you slipped in while I was typing John. Sound like we agree.
I also agree with the smaller cutters although the larger surface area makes it easier to get a really smooth finish without those little ridges. Remember Franks vessels were wide open and highly pierces so the inside had to be perfect. I useally do most of my hollowing with the 3/16 cutters and then if necessary go to a tear drop cutter that has a long cutting edge.
Hi Pete, Nice score!
To add to Paul’s comment, McEvoy Retired and sold his big bar system to Carter. He Also sold his videos and some tools to Woodturningtoolstore.com out of Texas. Recently my club, HVWT, obtained a copy of “ Brian McEvoys Secrets to Mastering the Large Captive Boring Bar.” I agree that McEvoys video that is dedicated to Frank Sudol must be seen. The dvd refreshed many points that Sudol made when I attended his sessions in Aaw Providence symposium in 2002.
Also available from woodturning tool store is a link to all of Brian’s archived newsletters which may be of interest to you. After seeing the video, Recently bought and tested one of his(or McEvoy) T1 teardrop cutters. I was really impressed with the cutting but thrilled with the longevity of the cutting edge. I used it with the 3/8 Jamison tool holder. I concluded For most of my hollowing I will continued to use Lyles swivel hhs and carbide 3/16 cutters. This teardrop cutter will have a future role depending on the form.
You asked if there are other bars that use a 3/4 tool holder. They will fit the Clark Hollowing Bar which I have the pleasure of owning. I integrated it into my Jamison like system. http://www.theokspindoctor.com/.
It is ironic that a friend of mine just milled a piece of 3/4 round steel so that I can make an articulated cutter holder for a variety of tools including the tear drop. Hold on to your 3/4 cutter holders. They are gold. I have not found them on the web. Carter will not sell them separately without buying the entire system.
Also note that your 60 inch bar is square which helps inhibit rotation of the bar when cutting. That and your D-handle indicate that you will not need a top restraint roller. It’s fairly stable. I would go with it when you are ready.
Thanks!
Pete,
I have a similar system DYI. If you go over the rest too much, you will get bounce, so then you back off. But in my experiments, that was about 24” off the rest.
And it looks like you could build a bar over the roller to make it captive, if you really want.
The other consideration is weight. If it’s really heavy, then it won’t slide that well on your rest and you loose that fine delicacy.
Otherwise it looks like. A great system. Congrats!
Hello all,
As mentioned, Brian McEvoy built his system based on Frank Sudol's design. Together with Gord Langer, Brian had many hundreds of these systems manufactured and sold them and other tools. In 2013 or early 2014, Brian and Gord sold the large captive boring bar system to Carter Products. Carter Products markets it as Hollow Roller XL. Brian and Gord still sold Elio drives, DVDs, piercing systems. They also continues to manufacture the T1 HSS teardrop cutters (for the boring bar) and supplied Carter Products with them. They produced a newsletter that they published about every month or two.
I was a subscriber to the email newsletter “The Lathest News” published by Brian McEvoy of OneGoodTurn.ca and Gord Langer of LangerCraftworks.com. When I got an email in March 2017 that they were planning to stop the newsletter and their tool sales business, I reached out to them with a proposition. After some discussion we had reached an agreement with Gord and Brian to purchase their equipment inventory and start an eCommerce business. With their blessings, I have continued to create and share “The Lathest News” email newsletter.
The Woodturning Tool Store (https://woodturningtoolstore.com/) manufactures and sells the T1 HSS teardrop cutters and still supplies them to Carter Products and other retailers. We also market the Elio-DR drive center and enhanced version of the original Elio drive. We carry all three DVDs produced by Brian McEvoy including the one mentioned above - "Brian McEvoy's Secrets to Mastering the Large Captive Boring Bar"
This is a business I choose to pursue because I enjoy woodturning and I was out of work of a year. I hope someday to be able to earn a living at it. I am just starting out and growing the business.
Happy turning,
Tod
g0RIT6TJ6890YszFIPVJKX4yVJLTull_8BJDCHOxGWZLUcQy29u-9ewwD6ot8AawlcO8kGWkPIbUhk3vJ_hdv3HTQ1Ciuu_WDbsd0Attpb-JY4_4MfP3c3SoD_FnlHJddsjYzIYHSioWDwBJ0kHYWv0oStvyjt-dCVPyJdz-IZR8Aanz06HxWrWI2luwR399zDiaU2krXxejGCNcXAA3PDHSCQ3a1q-Jk3APer_PpG1rbUVkuNogDhpOnlUOwHI5jX4G25nDgLkIl_XmD8wLiLGI_IWukSX3cepoYsh52OzZA87O3t82jaUINDvai9-x5fS7nIPsmSNACs0lg25RBGO23gFi9wQhDvdZKCQLf2CIFncYIeAf1c6CoYpBcQUnCSvWyNIqAbqKxnS0gRVW8yq3KpaUeqUC1bBJzQ_XRM2bgc2rc_QkRSJ7AoXgcIi5itxfz7toOfNYGDWck-cmowKeocWhsiG226aEMpWg0tQnzAvEVsf4jptn8802CzIDtlICi1JrrNRfnaNH6eN7lqbFd_BorCBlKx2gMHSPu2jTjqhfcIln3YWbXNxnKpAxYm-TZZrrm5-Emh3_aBydmMSDRT1B0zpFU2CR_x7UAi6ev4ar3qDMD_ajLSOaWCr2jtiU_188kAt_j7fIQQOUj8w4EAJwEw_z=w800-h723-no
OtOluypqrRZktNu7BQke_oFGeAiXH9wzLAwLUYzddwxqzmbO5WkOW-DCI0W3LhO2Xw9q5hpUFqPowb_P99e9d-yvQTC09A4ZY7apzRJR3pv1_JWzVVdNgmWlwTNWmflj6Kxlvm4F4z-KHHvYQH07YZMQjPcsgnaVEOPF2WE06m39_iaEk2x5utNZcgM4tPMaAohtgBqbJZnzlDzCXPRawFqPAvNFfuvM0gD87v36RkGH3afZZIqp5cFbqzdYZxPzJGc6P6ttw_VrzFyhW9UBHaASpOF85b2dGSCTDiUFdFna-yQCyISGTHd20W_2T-7RrTgxg8Gc2y-Z_QJMkFBWezjEredK2ImbUTA7azs1954PFZS__uOo-GxjAwmXUBfUVU8o6MPp0Zy7Qw9165n_Jp_fQk44-QbA_DA6qcdAqz8wH0D8MD1gylFYlxzcguuXcof3TZH5GXciQm7P0rB4EoXvzIjvsWT_IjA0xrahHcSVlq11_J8bS0MS4B9MtANLAidTMFJhYPk_tVUuxobrVjvtJbpJEZCNojxwcPpQa8YsgEfXlzUVyVOGdBjREpjWg7TzjPnqGxTJMknklYwkFUD7cXKTGjAUpRTgq1mXcRBYPQOHhgFJMSiKstOF_ORAhb6kGpV3-Nrz38-4N_NZVrOBnmdlcJCS=w800-h427-no
6GlEqcK-0ycX4qHECwqSY4oYqVWzX9PLVi8rerCSiCtJUp5aJcLFjf6JqFIUFennxR3SWmLumAhvmlBSH_zl6zGMaZ_cOyfN8KDosTKET406_kgexkLZsz-wxxBGz-dhFAJfOAfQCX1FrLS8XzQPS6WjbPsUbFzjLFUTBxzLM2lb-L0-KB1qsLkyN-5ArzjccapEArhLHqHU93MgJPM-ml6GDWOcDlwXRmTqIb3-7LxXPJLwyYvcP12ZGKtvQ6s7CrFE4kkoHADzJrLSnN7t4-sAptfsUG9fmT4524x_Y5I3ngvuab77qwO0Qh3_sMgwRvvzrwBD90Wc46SbZIgpA0pR-I08QBnYfnGsFOhxksTaL9QEoqePqMYZShlAseOPi5g6gLxygk6-KIy8y9kTcdzTyzQYVyTwuvO2obSlwcHJotjhdNQISI48wI27gZU02uKkF1YvaZbazXrJt1vGyyS9fRv6R3nysHQIGrhilTErKbkgGW6ssD5mSl8gpb1plPip5P0aQTsFxW0LHwtE0T7E_hcZILXDCbRChDjBzQTHf9ql0f5K9wReYPpOIK1H7N_q2nMa3RwA5Jg_mTHCj1sdG1WJpFN9L1TwgEXtQyE--ZOi-dijk0a6cjNSuy7FuIcTrxf4VufoSifsrOxjRm0fQIe8z7-S=w800-h363-no
5fW6himF02b11VhEOX4ogIf3hby4V2OumYo017Nu8pwvC5aDnc0Vi4RfMx8Rzv1KhAxSSI3SDYvvtDXOtea2tSXK2N5gigR5RptORXkCkm5CpavjqZb2M1IReOjqxaMk-qF2q5JF3REXnZ3SLq-2PFi7M9NHf-dnXxcokyqH05Ab2V190V8nfQ1yrVZQcTFQrHaLYgtlLwp66UuJcYIS-n0_CBYFV4CgKHRHlRZrzeKBi0QJN9kW2Yn6T0A3fDfG8XlNU670iuRwsiq6hCCjCYLg-R6Ds2Ab2BalGVhXAcDANznGscXCLBaaEBO47-AYKXuroJ6UkdkjqCY-67wSs0fDRfNrcbClXKxTNimbpAaDwK4zVbSmIi9FI0BqOO0mEkxqmqMObHVnbknuLspOG4rFSd8roSElFQJHHMqnB8mysS6ONGTXr36DdwTAV7gmV4IroON_zTsjEiDXfeYPxM1M1VeKkNL4QLVTVobQg5StmBP7VdApKpypGxLYRSUujiwcfEsxQiS8008S01Zi89ofSepdYAt3FSqS7-TB1lJUGfMHanqeyn4vqZEblAFDc8J5IbUGfKskzKvfXZ_lduTZwUHBkWVaAM_47QOwEjDYhPc4V0eRtaKuDQmVOSu-vBnFbQVw_aPq-Q-J3fPbOYb8_cBqZjrl=w800-h283-no
xbT0o9UTLDD1tZAyYZM0LTra22M3FUya8MSbH7GrwCv2ZzIwlVXO3S5nortfhg-EBhxdWuRo0DeBrQ7KttNVBYXhChFggaG8At07rJFctOcsz7uZ_oLvytdM3EExKSZPElH5-38U4xb60zHrqeOeUj7ketTM5PFRTY6PEaD4Yxyq1hGi83ITo-ScrnX_G_Zk91t9Y3mVP35tEii8ahGw0Zu_xXLW-PXFjoymOfTBTfpi3JW0o_Y3Gy40N6jP1Aagb6qgb6ht46Q6kJyQuXw8qDTz21WCMOQXwYIhRg8D3tD1V-hsmNFC3A699L1j7w_T_PlBQmUGgs6_YT-CmYcYxN0UHGF1dg5AQfyLfGBoI4Y88nBQWDlsqp6kD9ju9j_faLClYxx-9MW5eKvYPqor2BNo-DHI6Sd_syHp64HfkCkuq5bHBm0Cy9GRaEZwSRCyf1Y-ss8mADbTCQ9R2x9JLSDaW0q8jJc5tq9aRa1q32rtseZ6yeEE5kKGOjk37IyPcj_Ui9wgaYw07UfBZT8EU6hUjmttNxXByVNZFs7nTZhDwBVjYU5WSLQ7pP6lWDj3bv-j6dHldm3wMPd4Z63a88mpb8i3hRuXkY2BSlnGyTfDAQwhQKZyQWNGeVN54G1HBURgKqtPdPZOWCEnqDmIARBaBhoTF9kM=s500-no
I saw an old article in the Journal. A maui guy, Gus Mauri and Frank Sudol introducing or talking about a new bit for Frank's boring bar. I met Gus last year. Are there any bits other than the round carbide for this system? The bit looks like a spiral cut router bit... Anybody knows where to get them?
Emiliano It's probaby a round nose milling cutter. I remember trying one of the smaller ones in my hollowing system when I saw that original article. It worked. Not sure in my amatuer hands at that time that it did any better than a 3/16" HSS cutter that most people use nowdays. The idea was it was kind of a bevel rubbing cutter but I remember having run backs across the bottom. I probably wasn't using it correctly as I said this was early on in my hollowing attempts.
One of our club members, he's been turning over 30 years, still uses a similar system and I just bought a bit on Amazon. I used his bar the other day. What it would take one hour with a 6mm carbide cutter on the Jamieson rig it took just minutes. Super rough cutting, so then I went over with the carbide, and then the Carbide tear drop... That's the bit ...
Emiliano,
Isn’t that a milling bit ?
Rich
Emiliano,
Rich
Upon further inspection looks like you are right. This thing removes wood fast. Not for the shy turner. Lol.
@Emiliano Achaval:
Thanks for stearing me to that Mauri/Sudol artical in AAW archive Fall 2001: Page 58-59. It’s a nice little aggressive tool for end grain. I agree with John, it does look like an end mill that may have been reground. It is very similar to an idea that was promoted a number of years ago by Jeff Nicol of woodennicol. Jeff took an inexpensive 3/8 HSS drill bit and ground it back. Enjoy his you tube.
View: https://youtu.be/TyN-RZOPB4M
and
View: https://youtu.be/gVvmCMp9cRQ
I hand ground my own (see below). It cuts great from center to rim even going up to the rim on an angle because it’s slicing like a gouge and the point of contact in the same location on the tool. When cutting in a parabolic path you may have to rotate it slightly to maintain a bevel cut, similar to a hook tool but IMO not as versatile. It’s use is limited with a captured hollowing system which by its nature prevents boring bar rotation.
For aggressive material removal, have you explored connecting a Pro-forme?
I believe you are right John...
@Emiliano Achaval:
and
That’s the same idea! His bit is way cheaper too... Thanks for sharing!
I took a screen picture of the Gus Mauri cutter . It's principle looks similar to Soren's cutter... Has anybody used Gus's one? I just ordered Soren's Berger cutter, direct from him in NZ. Iooking forward to try it...
Pete,
I saw a demo by Ron Campbell of the smaller Carter system, and he brought up a good point. He uses a Hunter-based cutter for getting close to done, then switches to the carbide cutter like Tod shows. The carbide is only used to smooth out the walls from the grooves that are left from first passes. It is easier to use than the Hunter bit as it is wider. Both have their place & use.
I have the Carter XL which is remarkably like yours, and love it. Loads of mass and cuts most wood very well. Super dry and knotty wood doesn’t do well, but I’m new to this and suspect that wood would not work well for any system.
I recommend adding a camera to your system. I switched my hollowing rig to use a camera instead of the laser. That was remarkably easy, & I hooked mine up to an old, used computer monitor. Total cost <$50. What I used is :
  1. Swann Microcam 720p Security Camera, 1 megapixel resolution. $25 @ Micro Center (uses a BNC Connector) (http://www.microcenter.com/product/481586/MicroCam_720p_Security_Camera)
  2. VGA video PC converter adapter with BNC $18 @ Amazon (https://www.amazon.com/gp/product/B00ENH8MTW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1)
Works like a champ, & really helps !
I do want to try the bit that Emiliano mentioned as I do a dit of end grain turning.
Good luck.
Rich
Good idea Rich. Where do you place your camera? I just bought on amazon. a WiFi endoscope which displays and records on my iPad. The WiFi camera will be attached to the boring bar. It has adjustable led brightness feature. I’m still in the process of implementing this method. I’m sure it will aid my boring bar-hook tool use. I often need to see where the shavings are coming off the tool in order to make more efficient cuts. (Like a skew or a gouge). This will aid when I’m 12+ inches in.
I still will use my laser for the outside wall thickness and I also like to use the original Sudol method of internal lighting to see finial wall thickness develop.
What angle (rotation) do you present that at?
Cuz I could see that leading edge digging in for a really nice catch.
I have done similar cuts, with a gouge, where the wing of the flute is presented sideways to the wood.
IF you get it right its really effortless, smooth cut. LOOONNNNG curls coming off.
Get it wrong and its a very nasty catch.
I'll only try that with a 4' long steel handle.
I do have a 4" 5/8 bar/handle, I cut from the inside out, with a slight angle up... I have been lucky, haven't had a catch yet... But, yes, its not for beginners or the weak of heart...
Emiliano: I have been reading the form on the AAW site looking for info to make a camera set-up for hollowing using my older Ipad for a monitor. I read that you used an Ipad for a monitor. Would you be so kind to tell me of your set up? I would like to know what camera you use, where it can be purchased, and how it connects to the Ipad for monitoring. Any other information which will help me set this up would be much appreciated. I am not very computer literate, so the simpler, the better. Thank you for your time and your work that I have seen is exquisite
These converted drill bits and mill cutters look like variations of the hook tools, or the ring tool cutters. I kind of think I like them better than the hook or ring tools, but may have to try them out some time. With the limited experience I have had with hollow forms, I had catch problems with the more tear drop shaped cutters, some nasty catches. I would expect a NRS would be far better for cleaning up the insides and with less risk.
I never could get the Berger tool to cut the way I thought it should. Probably would work better if I had a hands on work shop with it.
@AlanZ I believe he has a YOutube video about it...
Getting back to the Sudol teardrop cutter..... the pointy end is not much different than a 3/16 or 1/4 inch HSS cutter, and after removing most of the wood you can rotate it to the blunt end for smoothing. I believe this is how Brian McEvoy uses it in his DVD but haven't seen it in several years.
