Future project
Van Alstyne, TX
This piece of Bois de Arc.
It is a bit intimidating.
For one, never put something like to the bandsaw. I know it can handle it, but you know..first time thing.
As of now, no bowl type experience.
I know from spindle turning it is a wood that will require some care overall.
I do need to Learn on some typical pine building lumber first.
George - Not sure I entirely understand your comment about bandsawing this log, but you do not want to try and cut a round log on the bandsaw while it's laying on it's side. It can be very dangerous as the log will roll (be pulled down) into the blade. Typically the blade jams, or breaks, and/or worse.
You either need to chain saw a section or use an appropriate sled, or wedges, if cutting on the bandsaw is your only option. It can be ripped on the bandsaw if you take a few precautions.
I think @John K Jordan has a few videos he's shared on this forum re: cutting wood on a bandsaw
Re: bowl turning, just asking............but have you found a woodturning club in your area yet? If not, you should search around and try to join, or find a mentor, to help you learn how to turn a bowl on the lathe. Much safer to have a mentor to assist.
George,
I've cut a lot of Osage Orange (Bois de Arc) on my sawmill and on my shop bandsaw. As John Dillon mention, there are certain things you can easily do on the bandsaw, some you can do safely with certain cautions, and some you should never do. I explain these in my video.
I made the video for a remote club demo during the Covid Pandmic so it's long.
View: https://youtu.be/4Rbdas-jtD0
One thing to never do is to crosscut a round on the bandsaw unless it is well supported. Someone I knew tried that recently and went to the ER with a bad cut to his thumb.
You can safely rip down the center of a lot, off center if properly supported.
If the log section diameter is larger than the capacity of the saw, you can cross cut it first with the chainsaw to a size that will fit on the bandsaw. In this case the diameter doesn't matter. Sections of large diameter logs can be hard to carry and place on the bandsaw. I've cut up some that were 20" in diameter cut into slices 12" thick to fit my bandsaw.
This is a cut in progress. One flat end fit safely on the table. I draw a line on the top through the pith to follow. Separate the halves and
This method is good for a variety of shorter spindle blanks including for boxes and vases. Once it's cut in half it's easy to lay flat on the table and cut nice bowl blanks.
Ripping long lengths of logs is easy, but may need a helper to support the end that comes off the bandsaw table first. I've cut them up to 12" diameter and maybe 3' long. (Make sure the helper doesn't try to help by pulling on the log - their job is only to support the end!!
This shows a rip cut in progress, looks like it's over 11" in diameter. I use 1 or 2 wedges on each side during the cut, move them as needed. I like to draw a line down the length where I want the cut but some people just eyeball it. Best to cut through the pith. The video shows a couple of options to make it more stable. It's usually best to cut down the length of the of the pith. This method can give some long spindle blanks.
Then lay each half flat to rip. Could easily make cross cuts now to get shorter blanks, say for bowls.
Here's a pic of a typical bandsaw session wit a couple of logs. The hat is for scale. I turn very little wet green wood so all these were air dried before turning. The video shows details. BTW, I find a 1/2" 3tpi blade perfect for this. I use an 18" Rikon that will cut up to 12.25" thick.
Hey, I love Osage Orange! It's hard and heavy but turns cleanly. I once got logs from what was on record as the largest Osage in TN; sadly it died. The limbs growing vertically from the main trunk were bigger than most tree trunks.
There are some really good videos by Richard Raffan on YouTube that shows how to breakdown and process a log.
@George Speed
These are some walnut blanks (and a bucket of cherry) I just on the shop bandsaw in maybe 3 hours (not counting the chainsawing) using the "Standing" method, cut from rounds less then 12" long. Blanks are up to 4" square. Always cut small pieces into blanks for Pens for Troops.
I let all blanks air dry before use. Takes years for some.
I'll be cutting blanks for months - I have walnut, cherry, persimmon, y.poplar, and cedar, about to get more.
I'll probably cut the larger logs (maybe 30" in diameter) on the sawmill into slab 2"-6" thick , easier to manage and a lot quicker than using a chain saw and shop bandsaw.
Sometime I cut slabs on the sawmill, cut the slabs into shorter pieces, then carry some into the shop to make nice blanks while the others are stickered for air drying
1768841668470.jpeg!
It's easy to get WAY more turning wood that I can ever use! When I get good logs my favorite thing is to notify turning club members who come with chainsaws and trucks and trailers. I hold up the logs while they cut what they want, then I load the big pieces.
Last year a bunch of people came after maple from a neighbor's tree.
Some pieces were 4' in diameter. too big to mess with. I rolled those down into a ravine at the neighbors house.
I don’t believe for a minute you have internet deficiencies…..
Actually, just an enhanced sense of lazy.
Raffan has lots to offer. Thanks for the video links. That makes things easier.
(what a day, I'm about ready to collapse in the bed...)
You ain’t no lazy person either. Grass don’t have time to grow under your feet. You just a plumb wore out dog a$$ed tired ole boy.
Ok, after back from the wife's PT and trip to HD and groceries I started watching the third video in your list, (the one where RR was cutting up a short walnut log) and fell asleep on the couch. I think that was my 1st nap in maybe 6 months.
I liked the video - never saw that one. From the bark and look the wood it was like unlike any walnut that grows here (we have black Walnut). Maybe English Walnut?
He cuts up logs very much like I do. The main difference is I measure a lot and use the fence. I also find it useful to mark any defects I detect (cracks, etc) in the wood with a red Sharpie marker. The red shows through the Anchorseal and alerts me at turning time in case one end needs to be a tenon instead of the bowl of a goblet. Fortunately the other's I've cut from the big log had no significant cracks.
Also, I've never stopped a bandsaw that way!
Thanks, I'll watch the others later tonight. Now I need to walk down and close up the barn, check on the lame llama, make sure the horses have enough hay for tonight, and construct a knockout bar for a friend. I have a 3/8" galvanized steel rod ready, just need to thread one end and turn a knob from persimmon or something hard. Oh, and finish cutting up the last 1/2 of my own 10" long walnut log section, already sawn down the pith. After maybe sharpening the bandsaw blade again. Then I can be lazy again!
