Gel super glue
Chinook,Montana
I have been trying to find information on the uses of gel super glue. Basically, would it be useful in my turning tool bag. I normally use thin and medium type super glues to repair or trying to prevent cracking. Has anyone used the gel in their turnings.
Well, you can read the information on the Loctite Gel Super Glue. My impression is that it isn't the best thing for woodturning.
Quoting the web link " The gel formula works on a variety of porous and non-porous surfaces and is ideal for vertical surfaces and small gaps. Loctite® Super Glue Gel comes in a self-piercing tube; it dries clear and sets without clamping. It is also resistant to moisture, most chemicals and freezing temperatures."
The small gaps made me think of repairing ring separation.
I have used the gel to fasten a silicon foam gasket to a plastic substrate. This was for an industrial problem. It worked so perhaps it could be used to fasten pads to a mandrel when doing a bowl base or with a vacuum chuck.
Stu
Jon, I use CA for many applications but it seems too brittle for that purpose. Also, it can penetrate and stain the work piece and doesn't stand out.
I do use Starbond and their accelerator. Great stuff. But as you know, segments in a turning will move relative to one another. Flexibility is important. Perhaps a syringe applicator with titebond.
I use titebond for segmented work. The original or TB II.
Epoxy is a great filler in my experience. I usually use Loctite.
Just my .02
Thank You Mark. I have been toying with the idea of syringe tips. I also use Titebond CA , but believe I am going to try Starbond. I was impressed with what I saw on their website.
I just purchased some epoxy for a beer stein I turned for a friend. I have limited experience using epoxy, but you don't gain experience until you try. I have ideas for the other uses for the epoxy, but want to wait until I finish the stein.
I started rough turning this hollow form today. The figure and coloring surprised me. This is from the last log I have of this Silver Maple. Was not expecting the pinkish hue. Then I noticed the ring separation. Would syringe tips and CA help to repair or am I simply out of luck.IMG_0392.JPG
Unless you are wedded to a certain size, I would try and turn past the cracks in the diameter, or just move the bottom up and eliminate them.
Thank you for replying Mark. I had every intention of turning that piece into a urn. But with the ring separation, that did not happen. I turned the piece down,trying to eliminate the flaw. Unfortunately, the flaw was greater than expected.
