Getting rid of surface swirls
Jackson, MS
Hope I don’t lose my hair imitating Richard Raffan making a box when I turned this today. It finished out nicely but I can see sanding swirls upon close examination. I can rechuck it without leaving chuck marks and refinish the surface. I’m thinking the course grit sandpaper was the culprit. Also this was a practice project so any helpful advice is appreciated.
If this was you, how would you fix it?
As a side note, my friend and local mentor Gerald Lawrence stopped by the other day to give me a lesson on sharpening bowl gouges. Fortunately I had that figured out before he got here so he gave me a tutorial on roughing out green bowls using my freshly sharpened bowl gouges. He also checked out my new lathe.
He also brought me a piece of Ipe which I’m trying to figure out how to purpose and a piece of bloodwood which I made the finial for the lid of the box. It’s also funny how 2 pieces of cherry are different colors.
If talking about sanding scratches around the surface of a spindle blank, I have learned several things to reduce/eliminate them.
First, don't apply heavy pressure through the sandpaper onto the spindle blank, just enough pressure to yield sanding dust.
Second, after each grit with the lathe running, reduce the speed to zero and hand sand the length of the spindle blank, against the sanding scratches around the diameter.
Third, don't skip too many grits. I've found it seldom necessary to use the next grit (80 then 100, 100 then 120, . . .) A suggestion I've often read is not to jump more than 150% of the current grit (80 then 120, 120 then 180, 180 then 240, . . . or 100 then 150, 150 then 220, . . .).
If sanding scratches are still pestering when sanding completed, after sanding with the next grit in a sequence reduce the speed to zero and direct a "raking" penlight light along the length of the sanded area to highlight scratches as shadows.
I don’t consider those as swirls. You get swirls off a random orbit sander when you don’t get rid of the swirls from the last course grit. To get rid of rings from the course grit, you shut the lathe off and sand with the grain with a thick felt or cork backed sanding block. Another help is to dampen a rag and wipe down the wood with the lathe shut off. This swells up the scratches and fuzz, and makes it easier to sand off when the wood dries.
