Came across this video that does an excellent job of testing and describing glue joint failures. Well worth watching if you glue up wood joints. Short answer for those that just want the conclusions:
Lignin strength < Glue joint strength << Cellulose fiber strength
In layman’s terms, all else equal (glue joint length/geometry), roughly:
Side-side strength = side-end strength < end-end strength
Recognize that side-end joints will have long term expansion stresses that will defeat these over time, this was not discussed or tested in the video.
Still, some good testing and discussion that is not what I thought I knew…
