Having the wing slightly uneven is not a big problem. You only turn with one side at a time.what's causing this?
Can I restore that right side by jointing the top edge & then regrinding the wings?L
With experience they will look the same.
The right side of that tool is unusable.
I see 2 potential problems. Without being there these are best guesses from having corrected grinds on hundreds of student tools
1.View attachment 46449
If you stop the edge on the wheel at one spot it grinds a dip.
I teach my students to grind each wing twice avoiding the tip
Then grind once across the tip. This avoids overgrinding the tip.
Had to go from wing edge to wing edge until you get lots of practice
2.View attachment 46450
The left side has a wide spot where you haven’t ground to the flute.
The wire like steel threads indicate the edge is too thin and bending rather than forming a sharp edge with the flute
When I get a new gouge I turn it upside down on a platform with top of flute square on the platform I shape the curve on the top of the wing and nose grinding a small flat. This is jointing the edge.
Then use the jig to grind the flat away for in an edge with the flute.
I use a 320 grit cbn wheel about a yr old on a new Rikon grinder so. It doesn't appear to out of round.Could the wheel be something other than true?
You can get a grind to match the set up of the varigrind, protrusion, and pocket position.Can I restore that right side by jointing the top edge & then regrinding the wings?
The left side appears thick as I did try to reshape the curve of the wings.
Thanks!
I had the Varigrind-2 and found it to be kinda loose and didn't trust it with my students. I opted for the S900 Sharp Fast System which although similar to the Varigring-2 it is much tighter in use as I believe it uses brass bearings to hold a tighter arc when sharpening so absolutely keeping the tool in the middle of the wheel (no accidental falling of the wheel accidents). Best used with CBN as always grinding with it on a stone wheel will leave a rut after a few sharpenings.Also, be very careful with varigrind-1 to make sure the tool doesn’t slide off the wheel. The Varigrind-2 is designed to prevent tools from slipping off the wheel. Many people dislike the varigrind-2 design because of the lack of freedom to grind across the entire wheel, but many don’t realize the tool holder can be used without the base part. I can stick my varigrind-2 tool holder in the v-arm like a varigrind-1. Not suggesting you need to switch though. Just need to be a more careful with varigrind-1 Is all.
I find the little bit of slack allows me to use a little more of my CBN wheel. If looseness is a concern then it would be easy enough for someone to add some tape or small vinyl tube (sliced longways) on the base to take up any slack. The Sharp Fast is an expensive fix, but any excuse to buy a new jig is OK in my book because it gives us extra stuff to pass along to other turners. Hopefully your VG2 isn’t sitting in a drawer never to see the light of day. If so then let me know what you want for it?I had the Varigrind-2 and found it to be kinda loose and didn't trust it with my students. I opted for the S900 Sharp Fast System which although similar to the Varigring-2 it is much tighter in use as I believe it uses brass bearings to hold a tighter arc when sharpening so absolutely keeping the tool in the middle of the wheel (no accidental falling of the wheel accidents). Best used with CBN as always grinding with it on a stone wheel will leave a rut after a few sharpenings.
I tell my students, if you can't stay on a 1" wheel, you have your eyes closed .Also, be very careful with varigrind-1 to make sure the tool doesn’t slide off the wheel. The Varigrind-2 is designed to prevent tools from slipping off the wheel. Many people dislike the varigrind-2 design because of the lack of freedom to grind across the entire wheel, but many don’t realize the tool holder can be used without the base part. I can stick my varigrind-2 tool holder in the v-arm like a varigrind-1. Not suggesting you need to switch though. Just need to be a more careful with varigrind-1 Is all.
Karl no it was sold a while back. Not worried about using more of the CBN wheel as it is CBN and is not going to wear out with student use.I find the little bit of slack allows me to use a little more of my CBN wheel. If looseness is a concern then it would be easy enough for someone to add some tape or small vinyl tube (sliced longways) on the base to take up any slack. The Sharp Fast is an expensive fix, but any excuse to buy a new jig is OK in my book because it gives us extra stuff to pass along to other turners. Hopefully your VG2 isn’t sitting in a drawer never to see the light of day. If so then let me know what you want for it?
I have had 2 non students who have been turning for a year or three during a hands on with a pro slide off the stone wheel and take a big chunk out of the wheel. Thankfully no one was hurt. I show my students how to sharpen with the Vector Grind Fixture, the Qneway sharpening system and the Woodcut sharpening system but as long as they are my students they use the Sharp Fast in house.I tell my students, if you can't stay on a 1" wheel, you have your eyes closed .
