  • Congratulations to Steven Gordon for "Dropped Ice Cream Cone" being selected as Turning of the Week for December 9, 2025 (click here for details)
Grinder bit the dust
Morganton, NC
I went out to turn a couple of green bowls so I could get back on a few I still needed to finish turn. I flipped the switch on my grinder to touch up a bowl gouge and about two seconds in it stopped. I checked a few things out, light on it worked but no power to the motor. Check some wires, pulled the switch off and couldn’t see anything obvious.
It is a Delta 8” variable speed that I’ve had for several years. I didn’t have time to do a lot of trouble shooting and the Rikon low speed was on sale for $127.00. So I turned the two green bowls and headed to Klingspor and bought it.
I had to plane a hard maple board to get the height correct and just about completed the setup yesterday. I had to stop to go pick up my granddaughter from Prek but will finish today.
I think the Delta is a switch problem and will check it out as soon as I get caught up on turnings. I need two grinders so hopefully this will be a easy fix.
The Rikon grinders do go on sale from time to time. I have 2 of the 1 hp models. They have enough power to run metal wheels. The 1/2 hp model just seemed too whimpy to me. They do run on for a while after you switch them off. The lights that come on them are worthless!
Easy to check the switch. Take off that panel, and put a jumper around the switch. If it ran a couple of seconds, it’s likely to be the potentiometer. You can get a generic pot on Amazon for just a few bucks. Maybe you can take that new one back, or spend that little bit of money and have a second grinder.
Well this one is the 1/2 hp model but I did sharpen a couple of 5/8 gouges yesterday and it seem to do fine. If I have issues I’ll sell a couple more bowls and buy the 1 hp model. Guess I should have researched it a little more.
I had same issue with my cheap Harbor Freight grinder—it died—and bought the 1 hp Rikon. I’m very happy. Needed 1 hp to turn that heavy D-way wheel. Good luck.
This one is 1/2 hp but seemed to turn the wheel fine and I sharpened a couple of gouges with it. May need to switch to the 1 hp if I start having issues.
Plan to jump the switch in a couple weeks to see if that’s the issue.
I have a old Baldor 8" slow speed grinder which has a 1 phase 1/2 HP induction motor with start winding and centrifugal switch that disconnects the start winding when the motor reaches run speed. The Baldor never slows down no matter how hard you try to grin on it, but it has 3/4" shafts so rather then buy specially made CBN wheels I bought the Rikon 1/2 HP grinder, which also has enough power for the task. The only problem with the Rikon is it does not have start windings and therefore takes forever to reach speed.
I have a 1/2 hp Rikon with two steel CBN wheels. It just takes 10+ seconds to come up to speed. Once at speed with the pressure we use you wouldn’t know if it was a 1 hp or a 1/2hp. I just don’t see the need for me to invest in a 1 hp for grinding gouges.
That 1/2HP Rikon was and is the best pure running grinder I have ever had. I had 2 1" steel CBN wheels on it and yes it took 9 or 10 seconds to turn up but when I shut it off it ran for about 13 minutes before coming to a stop. It did that before I put CBN on it also. Its just the best balanced grinder I ever had.
I have the Delta variable speed grinder. Shop used to be unheated and I had the experience when turning in very cold weather with two heavy CBN wheels that it would be slow to start up and then fail. There is a fuse in the base of the grinder. After several times disassembling the base to get to the fuse, I wound up replacing it with a slightly higher amperage fuse and no more problem. (Ive since put a mini-split in the shop and now don’t generally turn in such cold conditions).
Good - non-arctic shop is a huge blessing! I used to run kerosene heaters in three previous shops, fire them up an hour or so before I wanted to play.
The best thing I did for my forever shop was install a heat pump with five ducts/diffusers to distribute the air. In the winter I keep it about 68 or 69. Stabilizes the humidity in the summer too and helps wet blanks dry a lot quicker.
I did exactly the same thing and discovered my Delta had melted the insides. The switch and potentiometer were both fine. The variable speed Delta 8" grinders are a bit frail after a few years of use. My Rikon 1 HP slow speed is now 5 years old and going strong. Good Choice.
Ya know, that is a good deal. And there really is no absolute need to change those 8" 60 and 120 grit alum. oxide wheels. It will take a lot of years to grind those down to 7" diameter. A 120 grit white wheel provides a very good, very sharp edge. If I needed a new grinder today, given the price to replace my 7" Baldor with another, I'd be looking at that Rikon really hard.
