Grinding wheel problem
I had an accident with my grinder, the tool slipped off and got stuck between the housing and the wheel, damaging (taking small chunks from the edges on both sides) the wheel in a couple of places. Now the wheel has some high points that cause the tool that I am sharpening to bounce which makes it hard to sharpen. I have tried a couple of times to remove the high spots with my diamond wheel dresser to no avail. Any suggestions or do I get a new wheel.
Assuming based on the experience you're relating, the diamond dresser is being hand held. You need some sort of rigid guide for the dresser, hand holding won't do it.
As to the wheel having high spots, that doesn't sound good. Chipping on the edge of a wheel shouldn't cause high spots on a grinding wheel. Worst case you may have bent the grinder's arbor. Does the grinder vibrate since the wheel chipping? There is a possibility the grinder is vibrating due to an out of balance wheel giving the impression of high spots.
Take the wheel off and verify whether the arbor is bent. If so, get a new grinder. Otherwise try another wheel.
Now is the time to get a dial indicator, if you don't already have one. checking for bent arbor only a couple thousands off will be a problem you won't overcome.
I have the standard dial indicator and magnetic base, but as I searched HF for a picture, I ran across this one.....a, new item I think. Pretty cool, as long as that adjustable neck is nice and rigid:
https://www.harborfreight.com/catal...eatured+Weight,f,Sale+Rank,f&q=dial+indicator
Been there done that. obviously the first thing is to be more careful when grinding. You need a fixed diamond truing system of some kind. ONeway sells one. If you take one of the T shaped diamond cutters and put it on your tool rest and take very light cuts you can true it up but it's so much better with a good system. Don Geiger sells what I use. http://www.geigerssolutions.com/Tru-N-Dress-Grand-Slam.html
I would get a new wheel. A damaged wheel can come apart,.
At a minimum take the wheel,off the grinder a tap it with the plastic handle of a screw driver on the flat edge all around the each side. Each tap should make a ring sound from the wheel. A dull sound is a crack discard the wheel. This should be done with any new wheel too as they can be damaged in shipping.
Dressing a wheel to round is easiest with a tool that has a controlled depth and a diamond point.
don Geiger has a nice one.
With practice you can do it with a hand held. Don’t start the dresser at 90 degrees it will just bounce and follow the out of roundness you want to get rid of.
Start on the edge with the dresser at a 45-30 degree angle take very light strokes toward the center of the wheel.
Don’t let the tool bounce or ride in on the low spots.
Once the outside edge is round shift the tool a few degrees towards 90 degrees and widen the smooth part.
Use the smooth edge as a guide and keep dressing into rough parts edge making it smooth.
Keep taking strokes from the smooth to the rough trying not to remove material from the smooth part. Eventually you get the dresser to 90 degrees working across the whole surface of the wheel smoothly with no bounce.
You now have the wheel true round and dressed.
New wheel- why take a chance on the wheel exploding as stated. Cheaper than an emergency room. odie, that is an interesting picture- a dial indicator with a new Alabama socket wrench. :p Remember, I'm from Tennessee. ;) We have a football team.....sometimes.
John You mean our football team actually comes out to play sometimes. :) I made a homemade version of the Gieger wheel dresser out of a single point diamond, some all thread rod and plastic decking. I'll try to find a photo of it. It rides on the oneway tool rest and can be micro adjusted so it takes a little at a time off your wheel.
I agree! Get a new wheel. Might as well get a CBN wheel and save yourself the time, trouble, and expense of balancing a matrix wheel.
I'm glad you cleared things up about Odie's picture. My hasty and careless first look led me to mistake it for an Aggie socket wrench, but on second look I see that it has too many moving parts (more than one) to be used by an Aggie. :D
Toss the damaged wheel far into the darkness of the night. Buy a new one. Consider an upgrade to CBN wheel. You'll love it. - John
That thingy looks like an upgrade on the chewing gum and duck tape those hurricanes use .....see hokies vs hurricanes sat night on abc.....
Buy new wheel
Could possibly have damaged the bushing in the wheel when all the grabbing and grinding was happening. Even if the wheel only suffered a few dings that could be dressed out the wheel would still be untrue from a damaged bushing. You didn't mention what kind of wheel but many have plastic bushings that can be replaced. But if you've tried that already then I agree with the others that it's time for a new wheel. Not worth the risk of having a wheel come apart or the frustration of trying to sharpen on a hit and miss wheel.
The wheel should be discarded for safety reasons since the it could have micro-cracks now and could explode on you.
If you drop the wheel on the ground - sure.
But knocking a chip off - not really. But it will be unbalances.
All my wheels are scratch & dent - with chips. Took a dresser to them to get the chips out and then kept using them.
Many years later - no issues.
There's lots of concerns on the web about wheels "exploding", but I've never heard (or seen a post) of it actually happening to anyone.
Oh it has happened and there have been reports. It happened in our University metal shop. A big 10" wheel at 3450rpm. Scared the living daylights out of all of us and made believers out of us. It happened so fast the guy that standing at the machine just stood there. It was over before he could even move. Fortunately he was standing to the side and the guards captured most of the pieces.
Knowledge doesn't get any more first hand than that. :eek:
Thanks for sharing.
To which I would say: 3450 rpm is WAY too fast for a 10" wheel. The centrifugal forces become huge.
Read post #7 of here
http://www.practicalmachinist.com/vb/general/bench-grinders-1750-vs-3600-rpms-215968/
The other issue with schools / colleges etc, is that you get users who are not well educated around the tools. Either in specific usage or general practice.
I.e. not really paying attention, then possibly jamming the tool into the wheel.
I agree, that if used improperly, a user can destroy just about any well designed tool.
I did see a picture in a woodworking magazine once where a guy had about a 1/4 section of a grinding wheel stuck in his forehead. Not pretty. An emergency room friend also told some stories and commented that it was far more frequent than most think...
I did a quick look through the Norton catalog and it looks like 2485 RPM is the maximum speed for many if not all of the 10" wheels. I could be wrong, but my impression is that this wasn't a shop for students although students often are more attuned to safety than some experienced person who can't be told how to do things. A wheel spinning too fast doesn't need operator input when it decides that it's time to go.
Yea this was an industrial grinder. the wheel was probably 3" wide. It was a massive machine. Don't remember why it happened, it was too long ago. I sure do remember the sound it made. This was in an Industrial Art class.
