There has been a lot of discussion on what type/brand of power sander folks use on this site.
As a newb - I was wondering what the advantages were of using the power sander vs. holding sandpaper against the spinning form.
I assume one advantage is a more random sanding groove pattern with the power sander. Correct? Are you able to get a better finish with the power tool?
Or, is it simply an time efficiency advantage for those that do production turning?
Thanks in advance for any help!
