Is bigger better? I think the one on my Nova lathe would benefit with a turned addition on top. Good idea or waste of time to turn one?
This is physics. Larger diameter requires less force to create more stopping forces. Have you seen the disc brake rotors on race cars? They are as big as small car tires. Well almost. Same goes for bicycles, larger rotors mean less caliper pressure is needed.Is bigger better? I think the one on my Nova lathe would benefit with a turned addition on top. Good idea or waste of time to turn one?
@RichColvin, am I missing something? What does suggested turning speeds have to do with the size of the handwheel on the headstock, from the original inquiry? Thanks.
Webb, I must ask why you feel the need to add a larger diameter hand wheel.
Over my years of turning (30+), I have read many articles and postings from far more experienced turners who pushed the idea of turning slower rather than faster.
As Richard Coers noted, increased speed = increased torque needed to slow the spindle holding the object. And, this is all the more true when turning larger, more massive pieces.
When turning pieces on a lathe, the turner is required to pay attention to inches per second at the cutting edge. This was outlined well by William Henry Northcott in his book, A Treatise on Lathes and Turning, 2nd Edition, (1876). As Northcutt noted, the turner should use these values.
These are the speeds at the circumference. So, converting these values to RPM gives:
- Soft wood = 2,000 feet / minute = 24,000 inches / minute
- Hard wood (or ivory) = 300-800 feet / minute = 3,600 - 9,600 inches / minute\
1 revolution = circumference of the piece, which increases at diameter * pi
Using the values from above, we come to:
So, for a 10” diameter piece, you should be running the lathe at:
- Soft wood = 24,000 in/min x 1 revolution / (diameter*pi) = 7,639 RPM / diameter
- Hard wood = 3,600 - 9,600 in/min x 1 revolution / (diameter*pi) = 1,146 - 3,056 RPM / diameter
Northcutt also noted, “Many are of the opinion that it cannot be rotated too rapidly; but this is a mistake.”
- Soft wood - 764 RPM
- Hard wood - 115 - 306 RPM
Do note: a later guide (the source of which I don’t remember) notes that the speed should be
These seem to align with the soft wood numbers given by Northcutt.
- 6,000 - 9,000 RPM / diameter
- Using this formula, a 10” diameter wood piece should be turned at 600 - 900 RPM.
Summary: All of this is to say, that you should rotate the piece slower than many assume. And at such slow speeds, a smaller hand wheel on the headstock should be sufficient.
