Headstock pulley for General 260 Vs lathe
Status
Not open for further replies.
Sanford, NC
Restoring a General 260 with a reeves drive Looking for a headstock pulley for it the part number is 263-V2 according to the manual.
Thanks!!!
Springdale, Arkansas
The last model of the 260 General made used a 3 phase motor, VFD, and a 4 step "V" pulley. If it was my lathe I would consider going that direction instead of restoring the reeves drive. 3 phase motors are cheap on the used market. Good ones can even be found in the junkyard. I also would use a poly rib flat belt instead of V belt for more efficient power transfer.
Status
