Help Needed - Modern Peel-N-Stick Postage Stamp Pens
Dripping Springs, TX
Howdy Turners! I need help in figuring out how to do a project that has been nipping at my heels for a while.
I have been looking for information on how to use modern Peel-N-Stick Postage Stamps to do decoupage on pen blanks.
I have not had any luck on the Interwebbygooglewiki finding any information on even attempts at doing this...
I have plenty of information, materials, and skill to do the traditional Lick-Em-N-Stick-Em postage stamps. Mod Podge, multiple types of CA, Solarez UV Finish many kinds of wood finishes, and all the wood and pen tubes a guy would need. I am not interested in casting acrylics / epoxies as that is a road I am not prepared to travel. However, if this is a proven solution, I would at least like to hear about it.
My questions are; What is the best way to prepare the stamps? Is the peel-n-stick glue enough to stick the stamp down on the blank and not have it peel or delaminate a year or three down the road? Is it even possible to remove the sticky without destroying the stamp?
I can use the Mod Podge as an acid free sealer on the wood before applying the stamps, but is the glue on these new stamps going to leach out and/or yellow the project over time?
Has anyone done testing with topcoats to seal the modern stamps that will prevent the dissolving or color smear of the inks? I am thinking Mod Podge or a water-based poly would be the least radical one to start with before going to CA or Solarez. (I do CA finishes all the time with great success but will be experimenting with Solarez on deep gloss applications like this.)
The current cost of a First Class Postage Stamp is $.78. Random experiments could get costly so any help would be very much appreciated. Thanks!
It’s a proven solution
When I’ve seen pens done like that the stamps, small photos, tiny gears etc. were affixed to the pen tube and then the tube was put in a mold and clear resin was cast enclosing the stamps inside. When turned and finished the clear resin shows off whatever was glued or stuck to the tube. Often the brass tube needs to be colored or wrapped with paper so no odd bits of brass shows
The place to go for great pen information is penturners.org
And the free tutorial library
Thank you Richard, I had tried to search on their web site before but found the search function was members only. However, your note urged me to try again and I found I could manually read through all the topics. I found some great ideas and things to try on other projects, but none that addressed the modern Peel-N-Stick postage stamps. A great resource though and was worth the look and see!
Turners warehouse (TurnersTV) has a tutorial for this exact thing on their YouTube channel.
Thanks Daniel, Chad at Turner's Warehouse did a fantastic job on his YouTube Turners TV live stream "Making Stamp Blanks - Live" and I watched it when it first came out (July 2025). I did watch it again tonight. He talks about doing old stamps, stocks, and other paper materials to be casting blanks.
At the 49-minute mark, he addresses a question about the modern Peel-N-Stick stamps but only directed at the casting method. He has done the Peel-N-Stick stamps as he mentioned several throughout the video. All the ideas he talks about are good information for paper items incorporated into pen blanks. I still want to hear if anyone has successfully used methods other than the resin casting to make blanks. We'll see!
