Help with dried wax
Victoria, Texas
This piece was finished with a coat of shellac sanding sealer and three very light coats of lacquer. For some reason, I thought it would be a good idea to add a “small” amount of wax. The idea was to let the wax dry and then buff it off. Well, it didn’t work out like I had hoped. How do I get rid of the dried up wax without ruining the rest of the finish? I tried steel wool with no luck, I tried buffing it with no luck. Will denatured alcohol work?
Well unless you rubbed out and polished the lacquer there isn't much point in using wax.
The urn in the avatar was sprayed with lacquer sanding between coats, then when no more brite spots showed I sanded to 400 then abrasive wool, then pumice and rotten stone after which the finish should have a smooth sheen. The wax just seals the sheen and the only time I had problems with dried wax is if there is roughness that didn't get filled in.
Don, I think you mean “well, when you don’t know what the hell you are doing there isn’t much point in doing it” but thanks for taking it easy on me.
mineral spirits will dissolve most wax. use a lint free cloth and just keep lightly rubbing it with mineral spirits. It should come off.
Thank you John! I’ll report back how it works out.
