  • Congratulations to Dave Roberts for "Low Rider" being selected as Turning of the Week for December 1, 2025 (click here for details)
High Build Friction Polishes?
Mark Hepburn
Artist & Chef
Houma, Louisiana
Question for those of you who use a friction polish. Which do you prefer and why? I'm using Shellawax and Doctor's Pen Polish but read about Mylands and wonder if there's anything out there that is more durable in this category.
My primary use is for small boxes and pens. Thanks!
So easy to make and you probably have everything on hand. Equal parts BLO, shellac, and denatured alcohol.
I keep un-waxed shellac powder on hand so I double the alcohol. I use 1 ounce of powder (3 level tablespoonfuls) per 8 ounces of shine juice.
I prefer mine because it’s inexpensive and made in small batches so it’s fresh and works well. And no shipping charges.
Bill and Jeff - did you put a wax coat on top or just the polish?
Also, what’s your go to finish?
My go-to finish for boxes and small items is the friction polish from Doctors Woodshop that is made up of walnut oil, shellac, and Carnuba wax. It goes on easily, dries quickly, and the Carnuba wax makes it quite terrible.
I’m currently using that but have durability concerns for frequently handled objects
I switched pretty quickly early in my turning adventure from friction polishes to hard top coats for things that are meant to be touched but not used for food. I started with polyacrylic then switched to solvent lacquer until I found the emtech line of finishes that are water based. I use there 7000 high build lacquer mostly. For small things like boxes I diluted some down in a dropper bottle with roughly 30% water and spray it on with an airbrush. If its going to be touched a lot I put a micro crystallin wax on top of it.
I think from memory, the Shellawax products cross-link with the oxygen in the atmosphere and harden up over 2-3 weeks. Much of what I do these days doesnt lend itself too well to friction polishes.
