Hi, all,
I have an older S750 Stubby. It has a remote pendant on a cable with just your basic start/stop buttons, but the main controls are fixed in the headstock. I would like to move them off the headstock onto their own movable remote pendant, comparable to what is now a standard feature on modern lathes. (I'm not thinking rigid pendant, like the Oneway - rather, a pendant on a cable, like the Robust, PM, etc.) Does anyone have any experience with building their own? The switches all fit particularly in the headstock casting - with a 7/8" bore for each, but with an unusually long body spanning the thickness of the headstock wall. I was thinking that all the relevant wires (all 16 gauge) from the VFD could be simply cut and spliced to rung the additional cable to the box. The box will need to be customized to hold the switches and wires.
I have an email in to Rod Caddaye at Stubby, but thought I would see what the hive mind of resourceful folks here would advise. Thanks for any words of wisdom you can offer.
