Homemade Threading Jig
I posted a while back on how to make a threading jig. Taking the ideas from the post, searching the web, and input form a club member I was finally able to make one with somewhat repeatable results. The biggest challenge is eliminating runout. Dealing with off the shelf components and several mods I am somewhere between 0.005” and 0.009” runout consistently. I don’t think I can get it down any further and getting to this point was not without a lot of modifications. This jig is nowhere in the same class as one of the Baxter, Hope or ChefsWear jigs. It is big and bulky, but does work ok at a reduced price. I size the threads the same as the Alan Batty video using hand thread tools.
Description
1. Sliding vice from HF cost was $69 (with $20 coupon) The vice is mounted on a piece of walnut and I used a piece of corian between the way to maintain position.
2. Base wood block. This was drilled when installed in the sliding vice to maintain center.
3. Cast hand wheel, $14 from Amazon,
4. 3/4” 10 tpi all thread $5
5. Jam nut used to stop the advance into the part.
6. 1 1/4” aluminum bar I threaded. I tried the 3/4” rod couplings, but way too much slop in those threads. Left over material from another project and I already had the tap.
7. I added 3 set screws on each end of the aluminum bar to take up any backlash in the threads. There is a leather plug in the bottom of the set screws.
8. One Way 3/4” to 1 1/4” adapter.
9. Indicator. This is a must have. Way too much backlash in the HF threads and the scale for the vise is way too coarse. Also I do not cut when reversing the part. I back off the cutter reverse the wood and then bring the cutter back to cutting using the indicator.
10. BMwood collet system $89 Amazon. I didnt have one, but can use it for other things in addition to this.
11. 3/4" Diameter, 3/16" Wide 60° Double Angle Cutter, HSS, Amazon $40
12. I use the banjo as a stop so I can slide the jig back to check the male threads against the female threads and return to the same place (using the indicator) if addition cutting depth is needed.
I am able to do 3 different pi’s with this jig
13. This has a 3/4” 16 tpi all thread. One disadvantage is I could not find a 3/4” 16 tpi to 1 1/4” 8 tpi. Only thing was a 3/4” 16 tpi to 1” 8 tpi and only have one chuck that will fit.
14. This was the original jig. It has a 1 1/4” 8 tpi all thread where I can use most of my chuck right from the lathe. Instead of a threaded bar through it has 1 1/4” 8 tpi nuts welded to flat washers and those are screwed to the wood.
Here are some examples.
Left to right Elm 8 tpi, apple 10 tpi, Red Oak 16 tpi and ash 10 tpi
Closer view of the Red Oak with 16 tpi
