Hydro dipping lathe turnings?
Loveland, CO
HI all,
I am curious about adding hydro dipping to my toolbelt as another possible way to embellish some bowls and other turned items.
Hydro dipping can be as simple as spraying or drizzling some acrylic paint in a tub of water, and dunking the piece. The colors can be abstract, made to look like stone or marble, etc. But they also make hydro dip film. The film is printed with some design, it is paid on the water, sprayed with an activator, and you dip the piece.
While I look for and try to turn only the best/prettiest wood I can find, some wood (like the soft maples around here, that are very plain) could be a great blank canvas for more whimsical pieces. I've thought about making a small set of bowls for my twin grand-daughters with giraffe, cheetah, and zebra skin bottoms. Or I can hydro dip something I make them with lady bugs, for example. My buddies who don't really appreciate a nice wood bowl may think a bowl that looks "carbon wrapped" is cool. Could also play with a cherry bowl (keep it cherry inside), with a walnut grain outside.
The search here didn't return anything and there are only a few Youtube videos on lathe-turned and dipped pieces. But the process LOOKS stupid simple.
Anyone give this a try? Any tips/tricks? I'm probably going down this rabbit hole at this point so I'll be the guinea pig...
--Scott
Boy, I'm probably remembering mixed thoughts here, but I swear that maybe, I dunno, 25 years ago I saw a video of Rude Osolnik (Google him if the name means nothing) doing this process on his famed candlesticks. And for some reason I want to say it was on an old episode of the PBS show American Woodworker.
Yeah, a tub of water, float some splotches of acrylic paint on the surface, and gently dip the piece in and out past the paint, grabbing it as you dip in and out. The wood may need to be sealed first to prevent water absorption... maybe? Anyway, let the paint dry, do it again with another color.
When I saw this, the candlestick may have already been completely painted with a base color to waterproof the wood, then dipped into the water with the other small spots of paint floating on top the water, then drag the piece past the paint splotches.
Sorry I can't recall with greater clarity, but maybe that'll help.
I played with that (long time ago).
Tub of water, several colors of spray paint. Paint the surface of the water and use a stick or something to swirl the colors around. IIRC, I dunked the piece underwater and then withdrew it out of the water thru the paint (but could have been opposite order - dunk thru paint then remove thru clean water).
Messy (water and paint dripping everywhere - at least if you are like me with stuff like this).
Easy, as long as you're ok with random (takes some practice if you want control over the pattern).
I think you just have to dive in and experiment....
It was fun to play with, but as with other similar things I quickly got bored with it and moved on...
I do a lot of paper marbling, including making the paints which I use (from raw pigment, binders, etc).
I've also marbled some of my turnings, using acrylics and a water/carrageenan bath to suspend the paint. Apply an alum solution to the unfinished wood surface, dry, then dip through the paint. The paint will adhere only on the downward motion and run off as you lift the item from the bath.
Cf Mary Thouin in AW 17:3, 17:4
An example, marbling an ~9" multiaxis plate.. Notice that little paint remains on the surface of the bath after the wooden item has been submerged. Paint has to be thinned in order to float on surface. The paint washes off easily if done promptly. You could use gloves -- I can't be bothered
After a bunch of research, it looks to me like the preferred method is a water/carrageenan mix (carrageenan is just powdered Irish Moss, a seaweed that thickens the water so the paint will float) and alum on the wood pre-dip, just as R Henrickson suggested.
Should be fun to experiment with!
I watched a you tube video on shaving creme finish. in a throw away roasting pan, lay down a thick layer of shaving creme, smooth the top with a squeegee, drop various colored dyes on the shaving creme, gentle stir with a popsicle dtick to swirl the colors. The leaving the turning on the chuck, remove the chuck from the lathe and using the chuck as a handle dip the top surface of the turning in the shaving, twist lightly, then remove and squeegee off the shaving creme. It leaves a very random pattern of dye coloring. I tried it and it came out really nice for my first attempt. Very Suttle random coloring that really looks different.
Interesting. I've been trying to get my wife to do some embellishments on my bowls. Maybe this will spark her interest.
