If you had to chose a pressure pot....
Shingletown CA
I know your all probably tired of seeing questions about pressure pots; but I've got one more!
What is the difference between the California air tools 5 gallon pressure pot (365C), and the C.A. Technologies 51-507C ?
Is it worth spending over twice as much? The tanks look the same.
Shingletown CA
I see the CA Tech pots have a higher psi rating. But that Teflon coated pot is probably easier to clean
Saint Louis, Missouri, USA
I have the California air tools 5-gallon pot and am quite happy with it. I forget which but the top has max pressure of 80 or 90 printed on it and I can't imagine needing more. For spills I put a plastic liner in it so clean up is a piece of cake. Next one will be bigger. WoodCraft sells this one.
Bay Settlement, WI
I spent a lot of time looking at cheaper pots, conversions, etc. Then I walked into my local Woodcraft store while they had the California Air Tools pots on sale ... walked out with the last of their stock and couldn't be happier!
Shingletown CA
Thank you all for your advise. I went with the CAT 10 gallon pressure pot; I'll have to remove that paint stir thing.
