Interesting Cube
David Springett does all sorts of work with cubes and spheres.
They run from super complicated to simple.
He has several books woodturning wizardry, woodturning magic, elliptical woodturning, turning full circle…..
This could be one of his designs
I saw this cube and wondered how it was done, so I had to attempt. First challenge was how to hold the cube without marring the wood. Second challenge was each bowl had to be as perfect a hemisphere as possible or the "windows" would not be identical.
This is a mock up of how I did it. I didn't have the tower jaws at the time and it still worked. I tightened the cube and culls in the chuck then hot melt glued the culls to the chuck jaws. I cut a circle template for the bowls to get them as precise as possible, then went back and fine tuned as needed.
All in all a fun project, I hope others will share their procedure...
That was my idea. I think I wrote an article for the journal but will be glad to look it up. I was issue 32-6 pages 28031. It simply occured to me that if you turned a bowl into the sides of a square and the bowl was the right size they would create a hole. So I drew out a diagram and played with circles until I found the right overlap. You can see on the photo with 3 cubes the one on the right has more holes in the center. I used a 1/2" round over router bit in my drill chuck to create those small bowls.
That’s ingenious!
