Is "Power Supply Off" necessary?
Evanston, IL USA
To the best of my knowledge, many modern lathes have a main power supply switch in addition to the basic "Forward, Reverse, & Stop" switches.
Is it important, recommended, or necessary to shut down the main power supply at the end of the day?
I not only kill that main power switch on both lathes, I have power kill switches wired in at the wall receptacles. I never know when something sneaky is going to come down the mains from the pole outside.
If you ever see ball lightning go across the floor inside your home, you wouldn’t even trust the kill switch.
Phew! The next two phone calls would be:
1- 911.
2- insurance company!
Assuming I live to tell about it! 😳
Family lore is that ball lightning rolled in an open door, across the floor and killed my great grandfather sitting in his chair. I never have been able to confirm the story, but the elders always told the story.
I just unplug at the end of the day.
Don't forget to unplug your compressor, dust collector, bandsaws, table saw, grinders, jointer, miter saw, shop vac, planer, battery chargers, tv, and drum sander! :D
Seriously though what is the criteria for what to unplug? I do have some tools that have electronics that stay on when switched off, on outlets that I switch off. I know that doesn't eliminate lightning damage, but I do have insurance.
Personally, my concern comes from protecting the VFD system, which I don't have in any of the other tools you mentioned.
I unplug the lathe when I’m not in the shop, and turn off the SawStop; otherwise I don’t unplug typically. So electronics in the Oneida dust collector and PM overhead air filter are active (b/c waited my for RF switch signal) just like TVs in the house etc are.
I do have a whole house surge protector wired to the load center (realistically for in-house line spikes, not for direct lighting strikes). Guess I’m rolling the dice for lighting strikes…not too worried about it.
We travel frequently (~half-time) and do typically flip shop load center breakers off if we’re going to be gone for more than a month. Not that a lightening strike couldn’t jump the house load center, then shop breakers, and then tool switch…but that’s just what I do.
As others have said I think the only real issue is not leaving VFDs and my SawStop circuitry always powered up, not for a lightning reason but just continual bias.
For my PM lathe I have a separate 220v disconnect plus a 220v surge protector plugged into the wall. And still unplug when traveling or a storm threatens. A disconnect switch is not ultimate protection from lightning surges.
All computers have good UPS and those plus everything else with electronics that runs on 110v power is plugged into 6 or 8 outlet Tripp-Lite surge protecters as recommended by tech pro son - these come with connected equipment insurance.
I started buying and using more of these after lightning struck a tree in my woods a few years ago - took out a fence charger at the horse pasture, a TV, and a desktop shop computer motherboard. Audio/video things plugged into the Tripp-Lite were not affected. I think the spike came through the ground and traveled to the shop through an underground ethernet cable. (Fried some ethernet switches and a router in the shop too.) I always buy good warranties on computers so a tech makes house calls to replace such things.
Note that whole-house surge protectors for breaker panels are available at electrical supply companies. The utility company not far from us put them on every breaker panel in their service area at no charge.
At the end of play each day everything in the shop except phone, wifi, microwave and furnace is unplugged.
With more tools, equipment and appliances having sensitive electronics having a good whole-house surge protector is recommended. For new installations or upgrades they are required by code. For anyone that doesn’t have a whole-house surge protector in their main panel, I highly recommend that you do. They are not expensive and are easy to install (for an electrician!). Of course that won’t protect against a direct lightning hit, that will also cause a fire. But insurance will cover that.
Now, if you are leaving your house or shop for extended periods of time, shutting the water off (and freeze protection) will save more mishaps statistically than unplugging stuff.
I'm not trying to persuade anyone to not unplug equipment, or argue that you shouldn't. Was just curious of the rational to decide what to unplug.
I should have been more specific, I mentioned the sensitive electronics; I unplug those when i fear a thunderstorm may show up (or if our power goes out). Actually even the slightest chance of a T storm. Otherwise they stay plugged in. The power outage thing is because sometimes once things get reconnected on the grid there's a real surge in the electric.
We don't have power spike issues here. Rarely have lightening. (We have had a couple power outages during 100+ mph winds.)
I've never had a problem nor concern (of course, as a lawyer or investment firm would say: past performance does not predict future outcomes).
But everything stays on and plugged in: lathes, remote switches for dust collector etc, computer, monitors, wifi router, cameras, smart thermostat, battery trickle chargers, garage door opener, ....
I do often unplug some things if we're going to be away for a couple weeks, just to save a few bucks on electric. But it's just too many things to deal with on a daily basis (vs the risk for me here). And I need to at least leave on the wifi and thermostat to keep the heat running.
It's all designed to be left on, so I leave it on.
Of course if you live in an area where lightening is typical (or electrical service is suspect) then you need to take extra precautions. Just sharing my situation....
That’s fortunate! The tree struck at our place was maybe 200’ from the house, 600’ from my shop. The lightning split the tree - I found pieces in a circle almost 100’ from the tree trunk! Sounded like a bomb exploding.
Had other trees hit and blew off bark down one side but they recovered. Many of the y.Poplar trees here are huge, over 3’ in diameter.
A friend brought me a log once for my sawmill - said it was walnut. Cutting into it I found it was actually y.Poplar. A lightning strike had burned a deep grove down one side, about 1/2” wide and 4” deep. It turned the wood dark inside with some beautiful purples and other colors. I understand some people call this “rainbow” poplar.
Well yes for VFD'S etc but other wise the stop switch on the lathe should be more than adequate.
I know of a house that has an aluminum/aluminium flag pole about 20' off the front of the house. The pole took a lightning strike as witnessed by the owner. It still badly damaged a nearby tree, destroyed the house electrical panel, and caused a fire, with structural damage, to the house.
Surge protection is a good idea, but adding "lightning suppression" (your web search term) to the exterior of the structure would be a helpful addition as well.
To avoid wearing out the plug and/or outlet, I wired in a double pole switch to control the outlets for my lathe and drill press. The lights above my lathe are powered off one leg of the lathe's VFD wiring, so I have a good visual indication if I've forgotten to turn it off. The work light on my drill press (which is powered by my old Problematic 4224 motor) is wired that same way.
Lightening strikes are weird things. We encounter one last year at our home. A nearby hit entered our house. Things you thought would be affected and things you thought that wouldn’t, were.
It caused the fire by arching the cast-iron gas line to the flex line of the furnace. Fortunately, the cast-iron pipe where the fire was didn’t have anything flammable around it. Best metal picture I can give you is imagine a torch with a flame the size of a basketball. The lightning hit sounded like a cannon was shot off just outside our front door. Afterwards the hot water would not come on. So when I went up to reset the hot water heater, I discovered the fireball.
Things repaired or replaced; refrigerator, wine cooler, tankless hot water heater, garage door opener, but no computers (surge suppression helped?) or TV’s. And of course the furnace flex line.
The one thing each damaged of these had in common was some type of electronics. So, should there an “power off”? I would say any tools with electronics should have some type of power interruption.
A fan? Does that get annoying?
I replaced a dead Delta VFD on a Jet lathe with a non-Delta and it had a fan. It was quiet. In fact, when shoping around others had fans. Some believe the lack of a fan is one problem with the Delta S1 VFDs used in some lathes. Some add fans. Some build a box around the VFD and add a fan and filter. I simply added a piece of filter material since sometimes there is dust around lathes.
We're up on top of a hill and have had lightning hit our driveway gate twice. The first time, it happened, I was walking down the driveway the next morning and about 50 feet from the gate, I saw a piece of plastic. I had cut the grass the day before, and figured I had run over something with the mower. I found a few more, then realized it was from the gate opener control box It looked like a shotgun had blasted right thru it, except the circuit board was all charred.
The 2nd time, it fried the gate opener electronics, but also traveled about 300' to the house and fried a TV, home theater receiver, a modem, 2 routers, and 2 of our 3 garage door openers. We ran out of water a few days later, so I'm thinking it took out our well pump too. A few months later when I tried to put on heat, I realized our programable thermostat was also dead.
When I replaced the gate opener, (again) I disconnected the underground power line to the house and now power it with a marine battery and a small solar panel.
I shut my Harvey T60 off every time as it has a fan in the box that runs all the time it's on. Don't want to wear it out.
is the fan by any chance temperature controlled after the motor cools it quits or is it running when you walk in in the morning and the motor is stone cold?
Answers to questions.
It runs as soon as I turn on the power. It's not loud or distracting. I think it is more to keep the dust out of the box than anything.
Box doesn't appear to get hot even after a long session.
I think he is referring to the VFD not the actual motor. The VFD that I installed on my LaBlond metal lathe has a built in fan that runs whenever the power to it is on. The motors themselves are what is referred to as TEFC (Totally Enclosed Fan Cooled) the fan is located externally on the motor with a sheet metal shroud that directs the air around the outside of the motor. The motor would only overheat if it was run at a very low speed for a prolonged period of time.
Yes in industry VFD controlled motors that run for long periods the motor fan is replaced with an electric fan that runs at a constant rpm to get around this issue.
Never unplug anything, never lost anything to lightning or power spikes over the last 70+ years. I know it can happen, but with that kind of frequency I'll take the chances of losing a couple hundred dollar VFD or TV set over the daily irritation of plugging and unplugging dozens of things in my house that might be damaged. I do use surge protectors or UPS on anything I think might be especially sensitive. The calculation might be different someplace with very frequent lightning storms, but I never lost anything in 17 years in St Louis with its near daily storms in spring and summer.
I have this planned for my new shop. A switch and outlet in a 2-gang box for my lathe. The table saw will have a switch on the wall but the receptacle will be on the ceiling.
Same here although I do get some great electrical storms, went down the path with some basic protection at the outlets. But eventually with the occiasonal reshuffle of the shop and sundry moves they were lost and never replaced. No dramas no losses in 20 years.
