I'd have to agree with Deitrich on this one.
Although sharp tools are a must, you'd have to be the unusual one to have started out cutting rather than scraping. I think that most of us start turning without realizing that there's more to it than just sticking the pointy end into the wood. I know I did. (In fact one of my first pieces I not only scraped it but began by turning a large piece way too fast!
It really doesn't matter how sharp your tool is if you just stick it straight into the wood. You'll get more tearout this way no matter what tool you use.
In general scrapers are flat in section and have blunt cutting angles. They should also trail slightly when engaging the wood. This means the handle is usually higher than the cutting edge.
In general cutting tools (like the skew, and gouges) edges should lead while the end of the handle is significantly lower than the cutting edge.
I like to recommend a good book by Keith Rowley entitled "Woodturning, a Foundation Course". Keith makes the basics clear and concise.
I also second the idea of getting in touch with a local club. It's a tremendous resource. Turners are usually quite helpful and will give you lots of tips, wood and advice. (See?)
They will also usually have a demonstration each month and let you know of learning oportunities.
Good luck with that little Jet. I have one and I love it!
