Jet 14" Bandsaw in Red Lodge, Montana
Status
Not open for further replies.
Red Lodge, MT
culinarywood.com
This band saw has been upgraded with a carter quick tension release, 6" riser block (12" cut under guides), Cool Block guides, and a wheel brush. It also has a fence system that includes a circle cutting jig. two new blades plus a few used blades included, as is an extra zero clearance insert. It is currently wired for 220v, but is easy to change back to 110v.
The saw works perfectly. The only reason for sale is an upgrade to a 19" saw.
Contact; sqrehd@gmail.com
Status
