This band saw has been upgraded with a carter quick tension release, 6" riser block (12" cut under guides), Cool Block guides, and a wheel brush. It also has a fence system that includes a circle cutting jig. two new blades plus a few used blades included, as is an extra zero clearance insert. It is currently wired for 220v, but is easy to change back to 110v.
asking $650
The saw works perfectly. The only reason for sale is an upgrade to a 19" saw.
Contact; sqrehd@gmail.com
asking $650
