  • Congratulations to David Croxton for "Geri's Basket Illusion" being selected as Turning of the Week for February 2, 2026 (click here for details)
Jig for cutting segmented pieces on SCMS
Toronto, Ontario Canada
www.phoenixwood.ca
Made this "micro-adjuster" for a DW708, could be adapted for other machines.
used a lamp rod which has fine threads and the brass couplings that come with them were soldered to copper plates that were tapped and screwed to a piece of angle iron. A piece of UHMW plastic is used a backstop.
with a small twist one can incrementally change the length of cut by a few thousands of an inch.
More info
I was using just a stop block and the clamp, and with scraps would nudge it back and forth so that my cut was within a few thou of the required length. Frustation set in and having to make half nudges or quarter nudges was disapointing. I thought of using a micrometer head to fine tune the stop block, but the cost was too much so i came up with this alternative. the stop block is now moved with fine adjustments of the screw thread. Wasn't it obvious??
The segment length doesn't have to be exactly, or almost exactly the correct calculated length. The segments for any given ring just need to be all the same length.
a greek key detail ring
i will show how/why this jig evolved, all because of trying to make a greek key detailed ring.
first i tried a design found on a sewing forum based on a 5 x 6 pattern, so if the wood strip was 1/4" then a block was 5/4 by 6/4 . but the joints required more precision than i could get with nudging a stop block.
then a friend found a pattern based on 5 by 7 but used mitred corners. in the pattern the white bits are identical so 4 pieces are done. then there are 2 other pieces that duplicate. the right side and bottom dark one and then the up-rights adjacent. to make these i had to get to within 5 thou in order for them to mesh together, even so i had to use the DS to fine tune the center piece to get them all to sit nice.
after several hours i had enough blocks to make the ring
http://i35.photobucket.com/albums/d176/Rusty_tools/many_pieces.jpg
so far i figure about 13 hours from cuting the stock to forming the ring.
http://i35.photobucket.com/albums/d176/Rusty_tools/the_ring.jpg
the bowl is now in final finishing with some touch ups on the WB lacquer required.
13 hours..... :eek:
Holy Moses! How much time do you put into these things? I'm a perfectionist, but I don't think I have this much patience! :rolleyes:
Nice work!
Dr_dewey
Please share with us a picture of that bowl !
Gary
