I debated with myself for quite a while, and decided that excellence needs to be acknowledged, even if the honoree blushes.
In the December issue of American Woodturner, John Lucas has an article, "Turning Captured Rings." This is probably the clearest, most complete, and best expressed instructional article I've ever read in our journal. As an example, check out photo #2, where you will see the ring I get on the left and the much superior ring that John explains how to achieve on the right. How did he know??? I've been at this a while, but I learned a ton from this article, and may now be able to get the results I've not previously achieved. Included as a bonus is how I might easily make some tools to get the job done.
Very, very well done, John. Thank you!
