  • Congratulations to Jim Mclain for "Carved Chaco Passages" being selected as Turning of the Week for September 15, 2025 (click here for details)
Just checking in
Gallatin Mo
I am looking at the Wolverine directions. Getting an idea of what is required for assembly. I am going to get some 2x4's and build a sturdy bench.. I will post pics when I get it closer to done.. Again thank you all for your generosity. I will never forget!
I just added a cantilevered shelf to my tool cart. There are very little force to anything when grinding. You just rest the tool on the wheel and let the grit do the job. Sturdy is about the last consideration. Height is much more important.
Richard, would you be able to post a photo?
I mentioned this before: I always mount the grinder and two Wolverine bases on a square of 3/4" plywood. This keeps everything aligned and lets me move the setup around on the bench, to a new bench, to the car to take to a demo/class, or to give an entire sharpening setup to a student/friend setting up a new shop. If you fasten everything to a bench and want to move it, have to redo everything.
You might be able to see the fronts of the two plywood bases under two bench grinders, three wolverine bases in use, all simply sitting on a stainless steel utility table. Could be clamped but no need.
What height would be best? I know most would say elbow height?
I like to have the grinder axis at about the same comfortable height as the lathe axis. Some of the same motions with hands and arms can be used for both.
Another advantage to mounting a grinder a plywood base is portability. I've taken my grinder on numerous road trips, mostly to classes. It has it's own designated rolling toolbox for the journey. I put rubber feet under the plywood base. It makes it easier to pickup.
The top of the shelf is 42.5” off the floor. I don’t like bending over when I am matching the bevel to the wheel. It has casters, but I don’t even lock them. Sharpening is a gentle operation that requires a light touch. What you can’t see is that I bought those pretty casters from Woodcraft that has the red poly tire on the caster. They have not aged well and are completely falling to pieces.
