Keeping green wood wet
nj
I tried this some years ago with logs and it worked to prevent end checking. Now, I use it with short log pieces to keep green wood wet and stop checking. I place wet cotton rags or paper towels on the ends and wrap with plastic wrap. Then I use poly stretch wrap to snug it all up. Works very nicely. You can re-wet the towels and reapply the wrap and it's cheap and easy and will prevent end checking for quite a while. It's a heck of a lot cheaper than Anchorseal and way more effective than paints.
I just use stretch wrap without the towels. It lasts a long time but does promote mold. Mostlly what I do now is use that as a quick stop gap until I have time to worry with the mess of anchorseal or melted parrafin wax. When I'm out cutting fresh wood I will often just use black plastic bags over the ends of the logs and wrap tape or stretch wrap around that. This keeps the logs in pretty good shape until I can cut them into shorter lengths or bowl blanks.
