Metal Detector for Turners
Gainesville, VA
I am amazed at the depth of experience on this forum. Anybody have any advice/recommendations on a good metal detector for the log blank cutting process? I just ruined a saw chain and put some serious dents in my gouge dealing with nails in a chunk of walnut that was too pretty to give up on. That is the second time that I have done this (I'm a slow learner) so I thought that I should check with you pros on a workable detector solution. Thank goodness I have not had nail bandsaw miseries yet...but I think that too is inevitable.
I have one similar to Damon, they work, EXCEPT, they miss anything deep in the wood.
Mine missed a 12p spike whose head was about 4 inches below the bark.
I bought a $20 metal detector wand off Amazon and it works fine. As a matter of fact, the other day I accidentally threw out a big allen wrench in my shavings. When I noticed that it was missing, I knew that it was in the giant pile of shavings that I'd dumped in the woods behind my shop. I remembered the metal detector and found that wrench in about 15 seconds.
A few years back a local guy got involved in importing exotic woods from areas where the Viet Nam war was fought. Last i heard he gave up the project because the wood had so many bullets and metal embedded in it.
For deeper detection of metal you usually need a larger coil that is designed for sensing the metal to deeper depths. A smaller coil usually limits the depth of sensing metal objects. A small hand held wand may miss certain metals deeper inside a tree trunk, whereas a larger coil would pickup metals buried to a deeper depth inside the tree trunk. You also want a detector that can cycle between ferrous and non-ferrous metals or have a design that picks up both types of metals.
