Miniature work. Let's see some for inspiration.
USA
I was pretty pleased with my little bowl that I made for a club challenge until I saw some goblets in the other posting.
So I started this thread to keep the other from getting cluttered.
What's the recommended tool for turning a toothpick? (please don't say skew....please don't say skew...) << fingers crossed.
The criteria for the club challenge was anything under an inch so I started big small?
I would use a SMALL skew. :) (I often use a 1/4" skew for small things or small parts of larger things.) Or, since you live in an unknown location I don't know if it's too far, but if not, come visit for a day, become proficient on the skew, and we can make some toothpicks and you can go home and make some more.
But if you just want to show the toothpick for scale, it would be easier to forget making one and just turn the tiny things on the end of a small, short blank held in a chuck, and show them along with a real toothpick, or with a penny like I do, or something else, for example,say, inside or around a woman's diamond ring. Or next to a pencil point, etc.
Turning from a small, short blank, I usually use a 1/4" detail spindle gouge, a narrow parting tool, some tools made just for small things, and a couple of small negative rake scrapers. That and some 600 grit sandpaper will do almost everything. I have chuck jaws that will hold down to a 3/8" round blanks.
Note that if want you show pieces along with a toothpick, maybe they don't all have to be made from the same wood - you could easily show things from other woods and have the toothpick can be there just for scale.
If you don't have small pin jaws for a scroll chuck like I use with Novas, you can take the jaws off and grip a small round or square blank with the jaw slides themselves.
Also, if the goal is to learn to make really tiny things, the diameter to more than the toothpick, I highly recommend first turning some larger small things for experience/practice then work your way down.
Note that there are other tiny things you can turn as well as bowls, goblets, etc. For example, I like to make tiny "magic" wands! This one from Ebony is about as long as the diameter of a penny. (not to scale with the goblet!)
Here is a small selection of my miniatures and a photo of Mt tools. My smallest skew and skewchigouge are .008" diameter. The captured ring on the smallest goblet is smaller than the 0 on the date of a penny.
What's a good wood to practice with when trying to make a mini? I'm assuming finer grain the better?
I've used many different woods. However if your making doll house miniatures you need to try to find woods that don't give away the scale of the piece. So yea tight grain or very small figures pieces are nice. I will also simply use wood that has no figure to give it away like Holly or Bradford pear. Ebony and blackwood are good.
For the super tiny pieces cherry and yellow heart have been good. Cherry is hit or miss but my smallest goblet that is.023" tall is cherry. I found that cherry has almost microscopic voids and if one of those end up.in the stem or walls of the cup then it explodes.
Hey John, what do you use to make the tools? Some look like they are ground from jeweler's screwdrivers.
Some were jewelers screwdrivers. Many are made using piano wire that I get from model railroad places. I mount the wire in aluminum shanks and handles.
