  • Congratulations to Jim Mclain for "Carved Chaco Passages" being selected as Turning of the Week for September 15, 2025 (click here for details)
Mobile base for 3520B
Yuma, AZ
I've just purchased a Powermatic 3520B with the 18" bed extension and I'm looking for ideas to make it mobile. One criteria is that the lathe must rest solidly on my concrete floor while turning. Somewhere I saw a picture where a club used HF trailer jacks to move their lathe, but didn't make a copy of the picture. Would anyone know where to look?
Do any of you have other solutions as I need to park the car in the garage as well.
I made a cabinet on castors that fits under the lathe. At each end is a scissors jack that raises the lathe so it can be moved. When the jacks are down, the lathe sits on the floor, completely disconnected from the cabinet. With the tools in the drawers, when you move the lathe, the tools move too.
I've seen several good methods. One of the best for a lathe that only has to move occasionally is to weld wheels onto some angle iron and then put some bolts on this same angle iron. You crank the bolts down to raise the wheels off the floor. This can be done to give you a larger footprint which really improves the stability of the lathe. The downside is, even if you weld the wheels on so the lathe barely clears the floor it still raises the lathe too much for a shorter guy like me.
My alternative was to make some removeable rollers. The downside of that is I have to use a hydraulic jack to lift each end of the lathe to install the wheels. No more than I have to move my lathe it's not much of an inconvenience. The good side is I put really large wheels on so it's easy to move it over small obstacles or even out on the gravel driveway.
I also have the system from Craft Supplies and heartily endorse it. It makes it easy to move it around for cleaning. The cost is high but it's well made. I used to use hydraulic lift table from HF to lift under the bed until I built the shelf described in the PM manual. It worked well but you need more room to wheel it around.
Enlightened
Thanks everyone, great suggestions. Now all I need to do is scrape up some more of the green stuff to get to the next level.
