More gadgets
Well, while surfing You Tube, I ran across this tool/toy. I believe it may be, at least partially, what I need for a flex shaft drive system for sanding, to fit in an articulated arm, where I will be able to run variable speed by driving it with a mini lathe motor. I found the took has many possibilities. I also ran into a page called Project Farm. Most interesting if you are thinking about buying any tool. This guy puts all sorts of tools through all sorts of tests to see which ones match their performance claims and which one work the best, with price comparisons. I would love to do what he does....
View: https://www.youtube.com/watch?v=d2gsiF-v33w&t=76s
I watched this one a few weeks ago, good stuff.
I wonder if anyone has tried the small (4"?) CBN wheels for electric chainsaw sharpeners that K. Rizza (WW) now offers?
I have the electric, maroon, HF sharpener which came as a bonus w/ the chainsaw I bought from another woodturner.
Years ago, I went from the simple guide to the Gransfors manual sharpener. It provided consistent sharpening of the teeth, but was kind of fiddly and every time I would use it, I had to remind myself how it worked and relearn it, as I use the saw at irregular intervals. On a whim, I bought the Stihl 2-in-1 sharpener, even though it really bugged me that it was so expensive. It's amazing how much faster my saw cuts after a bout of sharpening with this thing. There's still a moment of head scratching as to how to line it up when I first pull it out, but then zip-zop, sharp chain. I rarely filed the depth gauges and the 2-in-1 files them each time you sharpen, so maybe that's the difference, or maybe it's just more precise to line it up than a plain gauge. Whatever it is about it, it works, and I've made the money back by resharpening chains I thought were so bad I needed to take them in to the saw shop. It won't rehab a chain that's bitten the dirt or hit a nail, though. For that, I take them to the shop, but after seeing this video, maybe I'll invest in the HF grinder-sharpener.
I really like how he figures out a way to remove confounding factors, like using a bundle of 4X4s to make the task more consistent or hanging a weight on the bar to eliminate human factors. One thing he didn't appear to do, is to use a vise with each tool. At least he didn't in showing them in action. A vise really makes a difference for me.
That's a big difference. If you don't file down the depth gauges when you sharpen the cuts get shallower. If you skip it enough times the chain will not cut. The HF sharpener is ok but it has one flaw. The bar that sits behind the teeth that holds it in place is barley wide enough. One direction of teeth it fits well. The other direction its barley enough to fit behind. If your not carful it could change the angle on teeth causing the saw not to cut straight.
I have a cbn wheel on my Oregon sharpener. Big difference. Did not buy it from Ken.
Paul, I am not sure what metal they use for the teeth on chainsaws. If it is M42, or other high speed steel, then we can't get them hot enough to lose the temper. Same with our turning tools.
I did suggest to Ken that he make CBN wheels for the electric sharpeners a few years back. Apparently he liked the idea. I had seen some that were going for about $100, and figured he would beat that price. Now, I want some needle files from CBN to sharpen my 3 tpi bandsaw blades, and my big blades as well....
I really like this guy's channel, for any tool I can think of to buy.
The Sthil 2&1 is the best sharpener I've used, The electric grinding sharpeners remove too much metal and can take the temper off the teeth so they won't stay sharp.
I had the super cheap Chinese made electric from Harbor Freight and that was total garbage I then purchased the upgraded Chinese made electric from a local small box store (same as the Sthil except for color) and that was a little better. The problem with those units is: 1 the indexing of the blade is inaccurate and non repetitive 2 the clamping is poor and 3 the worst problem is the flex in the motor arm will cause variations in the depth of the grind relative to the pressure applied. The result of those problems is as Paul said and I don't think the metal is any kind of high speed steel since as soon as the blue shows up the edge does dull much faster.
