  • Congratulations to Jim Mclain for "Carved Chaco Passages" being selected as Turning of the Week for September 15, 2025 (click here for details)
More Pearl Ex Coloring on Bowl
Chicago Heights, Illinois
This was a piece of box elder that I dyed and didn't come out as planed. I sprayed it all black with auto primer and applied various colores using crumpled up Saran Wrap. I dry brushed the Pearl Ex into the Saran Wrap and stamped it onto the exterior of the bowl using a twisting motion. Then I dry brushed strips across the exterior. The checkered look was done by stretching a mesh Landry bag over the bowl and spraying the exterior with candy apple purple lacquer. The interior received a couple coats of clear gloss lacquer and then I dragged a feather loaded with various metallic powders across the surface. Varying the position of the feather produced a variety of strokes with little effort. I know the inside really doesn't go with the exterior, but with another coat of black paint I can start over again.
I really like the results on the exterior. I think that your willingness to experiment with different ideas has paid off. The interior is a bit too dark to see the results, but your description has intrigued me. I have some Inlace metallic dust and have tried to evenly apply it to a surface with unsatisfactory results. Maybe I'll try your technique.
I also occasionally do some experimenting if I turn something that I don't like.
