Mounting Burl Orientation
Ottawa, ON, Canada
Which is the best way for mounting burl; end grain or side grain? I have a 16" diameter maple burl that wraps fully around. I would like to make a larger hollow form with this if possible. The bark seems pretty thick.IMG_0528.jpeg
What is your objective? Hollow form or bowl? The burl itself usually has very confused grain so- orientation is not as important. But if you are going to include the limb/trunk… the grain of it should be considered.
I was planning on a hollow form if possible. Thanks
Other things the HF turners on here might want to know in order to advise you:
Are you thinking you will make one piece out of this, or are you thinking of parting it out and making several?
What sort of wood is it?
What's the diameter of the non-burl part of things?
Are you thinking a natural edge hollow form with bark around the opening or getting rid of the bark?
Thanks Dean, I was thinking of making one large hollow form with a natural edge. The wood is maple. The non- burl part of the branch is 6" at one end and 4" at the other side. Is it okay to keep the pith if the burl is mounted using end grain with the limbs running parallel to the bed as suggested ?
The pith will almost certainly crack. But the burl might be full of natural voids, bark inclusions, etc so a few extra cracks won't detract from the appearance. I would turn between centers in order to allow you to shift the piece around a little bit to optimize the form as the wood under the bark is revealed. I also would consider removing the bark before mounting, it is a pain to cut through and could fly off in big chunks. Mounting with the pith oriented in either direction could both be good. Depends on how big of an entry hole you want also. A "natural edge" may or may not include bark.
I removed the bark on "ThisWay"
double box
Thanks Michael. I removed the bark and was surprised how the size got reduced. Also there is a portion of the burl where the centre is already hollow. This might influence my plan. Perhaps, I might need to cut the burl into smaller pieces? Thanks againIMG_0529.jpegIMG_0532.jpeg
bottom pic looks like inclusion....be careful.....possible place to split
If must have hollow form u need to fit a plug to one end.....or turn he face grain....would have to be small and wood have 2 holes in side face grain.....end grain yellow glue to base might use dowel thru side/ plug with glue.....hollow will be safer than when shaping lower outside hf plus that inclusion needs duck tape on outside of hf...i like yellow glue over glue gun.....bowl safer than he with that inclusion
Forgive my late arrival to the party but I “figured” I’d add my 2/100ths of a dollar. That hollow pith and reduced size wound lead me to make smaller burl pieces on the bandsaw for the always growing list of smaller spindle and facegrain projects I enjoy. Looks like great timber for boxes, lids, inlays, small tool and utensil handles and on and on. Great piece of wooden entropy.
