MT-2 care and feeding?
Mount Juliet, TN
Had 2 different problems today on my lathe.
First , I had spur stuck in the headstock. Took some significant hammering with large mallet and rod to drive it out. Previously just had to tap out with rod, no mallet.
Second, I was drilling end grain and the chuck in tailstock slipped and 5/8" bit stuck in the wood about 4" deep. Very difficult to get out
Therefore: what is the right way to treat the MT2 tapers (male & female) on my lathe? Clean, grease, wax, etc?
Appreciate some tips about maintaining these.
Regis
Nebraska
You most likely had some debris on the spur shank that locked it into the taper.
It is a good practice to clean the taper surface each time you insert or remove the tool.
Even just inserting your finger into the hole and wiping any dust or debris is a quick and
easy habit to get into. If you have compressed air in your work space you can quickly
blow any dust and dirt out of the spindle bore. A soft bristle brush is a good tool to use
for this task if you have one. There are taper reamers available that you can use to clean
up a taper bore that is damaged if needed.
When drilling Morse tapers in the tailstock tend to come loose.
The # 3 tapers don't come loose nearly as often as the #2 tapers.
I frequently use twist drills with a #3 M T. Once in a while they come loose. I stop the lathe tighten the tailstock to grip the taper and then back it out. I have always been able to get the drill bit to lock onto the taper tighter than it was locked into the wood.
When I use a Jacobs chuck I hold it with one hand when backing it out.
Also when drilling I back out to clear the shavings every 1/2-1 inch.
Mount Juliet, TN
Appreciate all the info.....now to clean the wax out of my morse tapers (lol)
Jamie, That link was definitely thorough and I have extra shotgun brushes and swabs.
Thanks to all,
Regis
DFW, TX, USA
My understanding is that clean and dry is the best thing for MT.
I think it's common for the drill chuck to slip a bit, and like others I will hold the drill chuck in the tailstock while using it. Also a 5/8" bit is large enough that if I were using a regular drill bit I'd step drill (i.e. start with a smaller bit, then go up to the 5/8" bit) to avoid overheating. I'd probably use a forstner bit, though for anything over 1/2". You have to reverse to clear the chips frequently, of course, and it helps to keep the bit cool.
The times that my arbor got stuck was when I didn't keep it clean. My understanding is that the compressible fibers (dust) got jammed between the arbor and the taper. I blow air into the taper to remove dust each time I insert a new arbor, but sometimes I need to manually remove the debris.
I made my own taper cleaner. I cut a square spindle (1"x1"x6" or so) from a medium soft wood, then I cut a line down the middle of each face (lengthwise) on the table saw to make clearance grooves. Finally, I put it on the lathe and turned it to the MT2 shape. It mimics the spiral tool that you can buy, but it cost me only a few minutes of time.
Mount Juliet, TN
Barry,
I should have know to step drill that. I actually started with a 2" Forstner bit. That caused LOTS of over heating so I dropped back to 5/8". Should have gone smaller first.
I "think" that I've learned my lesson and will keep everything cleaner.
Thanks,
Regis
DFW, TX, USA
Regis,
You can step drill with forstner bits, if you do it in the right order. I do this by starting with the largest bit, then forming an initial cut about 1/8" deep or so, to form the outer shoulder of the hole. Then I step down to a bit about 1/2" smaller diameter and repeat. The second (and third, etc., depending on the size of the hole) forstner bit will track the center point of the previous (larger) bit. Once I get to final depth (or a little bit shy), then I reverse the process going back to the larger bits. When stepping up to the larger forstner bits, they stay centered based on the OD, not the center point. In the end, I end up with the same size hole, properly placed, but without the heat.
It's a bit more work to change the bits, but I think it's just as fast because each bit is cutting less wood and is therefore faster. And you don't end up with burned wood fibers. I hope this makes sense.
Also when drilling with forestner style bits reduce the speed a lot. You should be getting nice curls out. Advance the bit, pull it back out, and then advance some more. If you try to drill a deep hole all in one pass the bit will be much more likely to jam in place and you may not get it out without destroying the piece your drilling. Everything else above is good advice.
Brandon, MS
I do what John has suggested and in addition for large boring I use a Colt maxicut which does not need to be backed out as often. Another solution I have used as late is to use air directly into the bore hole while advancing the quill and then rarely have a need to back out a forstner bit.
Morse tapers and all other types of machine tool tapers are high precision parts that need to be treated as such. Keep them free of any contamination of anything. No oil, wax, metal protector, polish or anything. They hold by molecular bonding forces so anything that interferes with a perfect fit will prevent the connection from having the necessary holding forces and also will interfere with perfect alignment.
Minor damage to Morse taper sockets can be repaired with a Morse taper hand reamer followed by polishing with a SpinLMate tool. It's not nearly as easy to repair damaged shanks and even though it's painful to toss away tools, it's better than sticking it back into the repaired socket.
Beating on a knockout bar isn't doing any favors to the bearings and is very likely to brinell the raceway.
Here's one other thought about your seriously stuck MT. Early in the use of my used lathe, I began having the same problem and discovered that there was galling inside the spindle (and on the drive center MT) which is something I knew nothing about and still am not an expert. The galling has proved a vexing problem, which will require the services of a good machinist, if I can find a reliable one. Take a good look at the MT shafts to make sure they are 100% smooth and intact, and take a peek and run your finger carefully inside the spindle, too. If there's any irregularity or defect, you've got a bigger problem than mentioned above.
Haubstadt, Indiana
Whe drilling I also back the bit out every 1/2" - 3/4" and I also used compressed air to remove the shavings behind the bit before. I use compressed air each time I insert into mt Morse tapers.
Nebraska
Holding the reamer with a collet chuck or if the reamer has a morse taper shaft will increase
the accuracy of the reaming of the quill while it is mounted in the tail stock. This method reduces
the variables and errors present when mounting the quill in a chuck and trying to ream it when it
is mounted outside the tail stock. The video displays the common problems everyone will encounter
when attempting this procedure with another lathe.
Cleveland, Tennessee
Interesting thread and information here. I need to check my chucks, etc., plus check the tailstock and the headstock. Probably need to clean them.
Biloxi, Mississippi
Bill,
I understand you comments about wax, etc. in the MT2 bore. However, down here in Biloxi where I live humidity is high and rust is a constant problem. I clean and paste wax all exposed metal surfaces on my shop tools about once per month. How do I keep the MT2 bore from rusting where I can’t see it? It is pretty humid down in your home in Texas too, isn’t it? (By th way, I do blow out those shavings and reach in with my finger to check for burrs and such.)
Thanks,
Jon
I would be extremely careful trying to use a reamer. You could easily throw the morse taper off center. If there is some galling or torn places all you really want to do is to clean up the high spots. Any low spots will hurt the morse taper as long as they aren't extreme. If you try to clean up a morse taper so the entire inside looks like new you will probably mess it up. that should be left to a qualified machinist to do.
