need help setting up TL1200
Hi everyone, I'm back...sort of.....no longer on Bowen Island, Canada but down in S. Cal for a while working. It's been almost 6 months since I had my lathe set up...and I can't remember how all the pieces go together. I have the Nova TL1200 and here's the problem:
I have two attachment plates left over!
I used the heavy grooved plate to attach the motor to the lathe, the tail stock is attached with the flat plate and locking mechanism, yet I have two flat plates left, one locking mechanism and one long many sided bolt.
I need to attach the tool rest but the bolt seems to be too long. Although the base plates have hexagonal (?) holes in them, the bolt doesn't actually pass through, just rests on them. When I try to attach the tool rest I end up with about an inch too much bolt protruding through and the locking nut does nothing......and I have no idea at all why I now have two base plates left!!
Did I do something wrong????
All ready to turn and no place to go!
I also have mega DSL problems so if you can post on the forum, not personally, I should be OK.
ruth
