I've never seen any mention of recommended break-in procedures for new lathes, but I've got a new one on the way (PM 3520C) and figured I'd ask. Are there any recommended do's or don't's with a brand new lathe, beyond using common sense?
loosen set screw before taking face plate off spindle
The idea is to get the lathe In without Braking it.
Although things don't always go according to that plan.
Which model is that? Does it have a tapered sleeve bearing? Oil bath head?My Grizzly metal lathe has this procedure for a spindle break-in. May not be bad to do on your Powermatic:
Congratulations! Spindle break-in is complete.
- Set spindle direction switch to "F" (forward), ensure range lever is in LOW, and operate lathe for 10 minutes at 100 RPM.
- Operate lathe at 1000 RPM for 10 minutes, then turn variable speed dial to "0" to stop spindle.
- Shift range control lever to HIGH, then operate lathe at 2000 RPM for 10 minutes, then stop spindle.
- Run lathe in reverse at 2000 RPM for 10 minutes, then turn speed dial to "0", turn spindle direction switch to "0", and press Emergency Stop button.
And then , did you run it at the high speed (60 rpm) for 30 minutes and stop, then check if it came up to speed at the same rate after that? Also did you feel to see if the head got hot as Bill said above?My spring pole.lathe had a warm up.period. had to eat a couple of donuts and finish off a coke.
I recently got one of Teknatool's new 14" lathes.
Vitamins C and D?My spring pole.lathe had a warm up.period. had to eat a couple of donuts and finish off a coke.
2 of the 4 major food groups! (The others being chocolate and peanuts.)My spring pole.lathe had a warm up.period. had to eat a couple of donuts and finish off a coke.
As to the OP, it might be a good idea to follow any instructions from the manufacturer. Plus, if the lathe is stored outside, unheated, it'd be a good idea to run the spindle at low rpm to warm up the bearing grease before getting up to high rpm.
The roller bearings are packed in grease.
I recently got one of Teknatool's new 14" lathes. They had a break-in procedure which was to run the lathe at its fastest speed for 30 minutes. The head gets so hot after 30 minutes that you can't touch the head for more than 2 or 3 seconds. This is due to the bearing placement, two bearings on the right side of the head about 2" apart and then there is about 4" of shaft to the left with no bearing with the pulley and belt on the left end. This is the only lathe I have seen that does not have a bearing on each end of the shaft. To prove a point I ran 6 other lathes at the same time (including my DVR300 @5000 rpm) for 30 minutes while doing the same for the 14"er and not one of the other lathes was even slightly warm (they all have bearings on both ends). It is a very well made lathe except for the bearings, tis a shame.
I'm pretty sure the Powermatic break in instructions are:
1. plug in
2. turn on
3. make something
4. repeat
