new lathe for winter turning
Hi I am new to the forum and have been turning during the warm weather of the last few years. This winter I want to get a lathe for inside the house. I am renter and can't rewire my house, (without getting in evicted). I can't set up shop in my living room (without killing thousands in AV equipment or losing my girlfriend) nor can I stand to be outside most of the winter in the cold and wet that is central ohio (due to bad knees and less than Ideal turning conditions). I am looking for a lathe and Dust collection system that will fit against a 6 foot wall with some space to spare on either end. This will be in my laundry room which measure a total of 6x12 most of which is taken up by W&D, chest freezer, and a sink. I also need to keep the noise down because my rental is a duplex and my work space will be adjoining the neighbors laundry room (can't annoy her she is hot and may one day be a girlfriend).
My first thoughts are to get a mini lathe as I won't be making anything bigger than pens or christmas ornaments in an inside shop. I prefer to stay with 1x8tpi with a #2mt as my chuck and centers are already that size. What I would like to hear any opinions on is how the delta midi or jet mini compare to the PSI mini or anything bad about the PSI. The delta and jet are both good lathes but considerably more expensive that the PSI. Since I don't do much work from november through february as a landscaper I need to consider my budget. I already have a good lathe so I am not in the market to replace something either. If anyone has big ideas for controling dust in that small of an area I would love to hear them. My thought is to surround the work area with a shower curtain and have a furnace vent on a box fan. I know this method works for scroll sawing but not sure how it will work for a lathe with produces much for waste and dust.
Lastly I would like some advice on the good pen kits, where can I find them or order them cheapest from. I am just turning them to keep me from going crazy while holed up inside, making money from them comes later. Secondly is a self centering pen drilling vice, assembly press, or other jigs I haven't thought of are they worth the money. And the last item is completely unneccesary for me but I would like to hear any oppinions none the less. I am looking at the PSI super blank cutters http://www.pennstateind.com/catalog/p/045.htm I like the idea of starting with round pen blanks and the ease of making end grain blanks.
Also which would be a better buy a barrel trimmer or small belt sander?
I guess I should also mention for when I need them in my outside shop I have A radial arm drill press, radial arm saw, 14" bandsaw with risers, 5hp compressor, 18" chainsaw, and various other tools with no turning applications. For inside work I also have a mini drill press band and scroll saws.
grinder
I like what you did there barbara. I have sharpening taken care of, it slipped my mind as I have a complete tormek package that I take outside with me when I turn.
Jet Mini, definitely. It's the starter lathe of choice at my club and is an absolute workhorse. I've beat the crap out of mine for 5 years and have not had problem 1. Easy to get accessories and bits-n-pieces. Always on sale somewhere. Available in VS or step pully (I've got step and have no problems).
As to the mounting of the grinding wheel on the outboard, it seems that that would kinda compromise being able to hand stop the lathe. Also, if you've ever seen a wheel catch and come apart you'll understand why grinders have a shield around the wheel. S' like a bomb going off with chunks of rock flying everywhere. Good way to get bleedin. Took mine off when I changed my wheel to a white. Saw one go boom. Went home and put the shields back on real quick!
For a 6x12 space, Delta makes a prism shaped air filter unit that is portable to get all the small dust. There's a review on it in Wood Magazine about 2 issues ago. A good shop vac serves as the big dust, chip, and shaving collector.
Hope this helps,
Dietrich
P.S. (Barb, might want to think about retro mounting a wheel guard around your outboard. Doesn't need to be sturdy, just containing. Could make it out of sheet metal and mount it with rare earth magnets. Take care.)
Barbara. I went to the site you posted and found out a lot about the Nove Mercury. Howewver , all the dealers they listed do not have the Mercury in their web site. Where did you get yours from and for aproxamitely how much $ ?
I bought mine at least 2 years ago from Woodcraft
As far as I know, no US dealer still carries them because the market tanked for them.
-e-; Thanks for the reply. Tha is the kind of Info I was looking for.
I have lot of 1x8 and # 2 taper accessories. I need a lathe that they will work on.
Conflicting info;
I just read that the mercury has a 1x8 thread and #2 taper.
Is this maybe a metric measurments that are just CLOSE to 1x8 and #2 taper?
Barbara Gill; You have a mercury so should know for sure. Would you reply please.
Also I notice they have only 1 year warranty on electronics of which there are many on this lathe. Have you had any mechanical problems with the lathe?
I now have a Craftsman that is often broke down so I am a bit wary. :rolleyes:
1" 8 tpi RH inboard 1" 8tpi LH outboard #2 MT
I bought this lathe for two reasons. One, it is a perfect demo lathe if I should ever decide to do any. I put the sharpening stone outboard just for this so no grinder has to be hauled along. If the standard safety shield for demos is used and the turner is wearing the standard safety protection, injury from a stone that just might happen to break probably won't cause injury. Remember, the speed of the stone is controlled by the lathe speed controler. There is no reason to have it turning very fast. For general use it does not need the stone. It is easily removed. The lathe is light (59#) and easily moved.
Two- it is a great lathe for my granddaughter to learn on. She can turn decent size bowls.
I have had no problems with the lathe.
Indoor Lathe
Save the money on a grinder put it toward the cost of the lathe. Buy a morse taper "work Arbor" and mount your grind stone in the lathe. Bring the tailstock up for safety and build a little wooden platform to use as a sharpening guide
peace, out
Angelo
Please be real careful, Barb. The stone carries alot (and I mean ALOT) more momentum than an equivelent sized piece of wood. Probably wouldn't punch through a face shield but wouldn't do your chest or shoulder any good. Picture a chunk of rock shot out of a slingshot straight at you (even at relatively low lathe speeds). Not sure how good I'd feel about that even with my face shield. Chances are this will never happen to you cause it isn't super common and still, if you can make a cover that screws to the side of the lathe (even just a C shaped piece of sheet metal) it wouldn't be a bad thing.
Just my nosy opinion,
Good luck and take care,
Dietrich
