NIB Oneway bowl steady.....New in box.....sort of! :)
Odie
Missoula, MT
I have a Oneway bowl steady for sale.
It's new in the box, and everything is there. Everything is brand new, except the post.
The post has been cut down to a level that is suitable for a 16" lathe. I used this post for more than a decade, and it shows it.....but, is in perfect usable condition otherwise. From the bottom of the base to the top of the post measures 8 3/4". (edited to add that I have the piece of the post that was cut off. If you want to do some welding, you could use this bowl steady for a much bigger lathe...easily a 20" lathe, but might also be good for a 24" lathe.)
It will be suitable for any lathe with a swing of 16", or less with the shortened post,
Does not come with the clamp block, but these are readily available online.
(edited to add: I have clamp block that fits a Woodfast or Vicmarc VL240 that could be included at an additional cost.)
$100, shipping included to lower 48.
=o=
