I have a Jet 1640EVS lathe that is 13 months old. As long as I have owned that makes what I would describe as a muffled growling noise at around 110 rpm speed. The noise only occurs when the speed is at around 110 rpm. It will growl until I slightly increase or decrease the speed off of the 110 rpm speed. Also, I can hear a light growl when I am turning the lathe down to zero and the speed passes thru the 110 rpm on its way to zero. I have disconnected the belts and checked the tightness of all set screws on the pulleys. As an experiment, with the lathe running at about 600 rpm I pulled the plug and let coast to a stop and the machine did not make any growling sound. That leads me to believe that it is not a bearing issue. I'm also wondering if the noise might be associated with the inverter or the motor braking system. Other then this noise, the lathe works fine. It's more of an annoyance because it does not seem to effect the performance of the lathe although I am concerned that it may be a problem that could continue to get worse over time. I spoke to Jet support and let them listen to a recording of the sound and they want me to take the head stock in to one their authorized repair centers. I called the repair facility a they said it might take about 4 weeks before they could llok at my headstock.
Before I do this I was wondering if anyone has any experience with a similar noise and have any ideas on what may be causing this and if this is something I should be concerned with at this point.
