Nova Neptune DVR 55700 Inoperable
Mahtomedi, MN
My one-year old Nova Neptune DVR is dead and it appears the company is no longer in business and neither is Striatech Motors, the company that made the motor with a 10-year warranty. The problem began when I bumped the spring-loaded spindle lock button and it attempted to engage while running at 2,150 RPM. It screeched to a halt but did not engage. Afterwards it will start but quit after only 1/4 turn. The spindle turns freely by hand. I get an error code of 02, which the manual defines as "RPS_State_Error_0", but is not otherwise defined elsewhere in the manual or online. Another clue is the small lightening bolt that briefly appears on the screen when it shuts down, which a repair guy in Iowa told me indicates a load problem, meaning electrical. Question: is this machine toast? Can I fix it with a simple electrical component replacement? No help from Striatech. I have opened the motor and blown out the dust. The bearings seem okay. The display indicates a default start RPM of 500 but shuts down after only 1/4 turn following the start button engagement. Any ideas would be much appreciated. Thanks, Al Fletcher
Appears Technatool is still in business as is Striatech. Here is the link for Striatech I found on google.
Teknatool is still in business, just the USA arm is undergoing Chapter 11 restructuring. The expectation is that that will resolve with it being folded back into Teknatool International, which simply puts the USA on an equal footing with every other country in that regard. It sucks for now, but given that the rest of the world is like "what Nova supply problems?!?" I think it'll work out better for US Nova customers in the end. Reports do vary on customer support responsiveness, which I'd place squarely on US staff cuts related to all of that. Have you attempted to contact their customer service about your lathe?
Likewise, I've not seen anything about problems with Striatech, nor does a quick search produce anything about business issues with them. Recent discussion here also gets into a brand new Grizzly lathe which almost certainly has a Striatech motor and controller. Can you cite a source for news of problems with them?
Do a google search of An “RPS State Error 0”
“An "RPS State Error 0" typically indicates a problem with the Rotary Position Sensor (RPS) on a NOVA DVR lathe or Shopsmith
PowerPro system. This error often arises due to issues with the sensor itself, its wiring, or the presence of debris interfering with its readings.”
There is much more info on that page.
Thanks guys, I knew there would be help from this broad audience. Okay, admittedly I overstated the degree to which I was sure that either company is out of business; however, I have over a dozen records of my attempted contacts with both companies. Absolutely no response or help, except for one follow-up question from Nova that may have been from a robot. Their automated systems make it appear that they are viable but either they are all on Summer vacation or no one is around to monitor the recordings or e-mails. Either way they are both dead ends. Along the way others, such as repair guys from hardware stores that sell Nova products, have told me they were out of business, and since I was getting no help it made sense. I'm trying to fix it in time to finish a bowl for the MN state fair and I don't want to wait till some day in the future when and if Tehnatool can solve it's problems with Nova USA. Yes, I tried to reach out to Teknatool New Zealand.
Bob, I'm going to attempt to insert three pics of my partially dismantled motor to see if you can further guide me with ideas of technical possible fixes.PXL_20250717_194348782.jpgPXL_20250717_194416682.jpgPXL_20250717_194403433.jpg Thanks to all, Al
One more example of why I cling to "old tech". Integrated motors and controls that turn to bricks without proprietary support do not appeal to me. Technatool has some innovative products which work well for many people but if factory support is unavailable the tools become as disposable as Kleenex.
In your first picture, that board needs to be cleaned out. Here is an email to their tech support guy joel@teknatool.com. He is very helpful and just helped me with fixing and Er03 on my Neptune. The pictures will be helpful to him.
Al,
I did read on a Shopsmith forum, “…there are optical sensors on a small circuit board under the fan on the rear of the motor. As dust accumulates on these sensors, it finally gets thick enough to block the light and cause the motor to not start, and display the dreaded 0 error.”
I don’t think I’d be much further help but I think Lou has provided what may be an excellent solution by contacting Joel at Teknatool.
It sounds like some compressed air and maybe a clean (chip/paint) brush, with some gentle reassembly, might be your fix. Don't force anything and make sure the wires are routed properly.
Thanks Lou and Darryl. I did send a note to Joel after Lou's suggestion and he got back to me with some suggestions regarding cleaning the sensors. Now I just have to put the whole thing back together, which includes getting help from a friend with a bearing press to put the bearing back on the spindle. I just wish Nova had responded to me last week before I tore it apart. Accessing the sensors turns out to be a simple maintenance item by removing the back-end face plate. Hopefully it will run when I get all back together.
Thanks again for everyone's help.
So this SRM uses an optical rotor position sensor? Can you post a photo or point it out in the photos? There are other rotor position sensor options that might be less susceptible to dust. Seems like sensor-less or induction would be better options for a wood lathe.
Just remember to use the double MT2 alignment tool when putting in the front 4 screws.
Once again, thanks guys for all your help. I only wish I had turned to this forum for ideas when I first encountered my problem. By the time I had Joel's help with cleaning the optical sensor, I had torn apart the motor and while reassembling it I sheared off a six-connector plug on the motherboard, which destroyed the board. I can now report that Nova sold me a replacement motor assembly and it is now installed and working just fine. Yes, Lou, I used the double MT2 tool for alignment. Thanks for the reminder. That's a handy device.
