nova ornamental turner
By adapting some standard parts (boring head, cross slide table and rotary index head) that could be put together to do everything the JaHo device can do. Even large bowl turning could be done in addition to embellishments.
rotary index head
I haven't done anything similar but I can say a decent rotary table is a useful tool. I use mine mostly on the milling machine when I want to mill to certain angles.
Off the original thread topic (of course): the rotary table was also was the easiest way I found to help lay out patterns for chip carving on turnings.
Ed,
I’ve not seen much published about this system. In the end, I think it becomes more of a gateway towards getting a rose engine.
Rich
I looked at these type of things a couple of years back. I ended up cobbling this together.
It’s a small standard X Y Table from eBay for which I machined a custom Router mount. I reduced the speed on the router and I’ve made some of my own cutters using small HSS tool bits.
The overall setup obviously moves the cutter from the lathe headstock to the router and the workpiece to the headstock compared to that in the original post above. The setup worked well in tests but I’ve not got round to using it yet apart from that. These type of things work best with dense timbers which aren’t always easy to source at a good price.
I had the impression that Boxwood was common in the UK.
Or is it available but expensive in usable sizes?
Some years ago some turner friends joined forces to source and import a quantity of boxwood to the US, I got a few pieces from that deal, sections of branches (trunks?) 4" or less in diameter. Very tight piths, no cracking. Nice white color. That stuff sure is dense. Haven't turned any yet.
It is available in the UK but not that common as it is slow growing and expensive as a result. France seems to be the place where it is most abundent so contacts in that country would be useful.
Boxwood is very nice and ideal for ornamental turning. As Colin says though it’s not cheap and not often available much over 3” diameter.
I bought some 4” diameter pieces a while ago but by the time I’d turned off the bark and trued it up it was obviously quite a bit smaller.
I guess the closest thing we have to boxwood is Flowering Dogwood - fine grain, hard, dense (but not as dense as Boxwood). Also slow-growing and generally small diameters, especially if it grows in the woods. Occasionally a yard tree with lots of sun and in good soil will get large. A neighbor cut one down - I got a lot of blanks from 2x2 up to about 6x6. Dogwood can warp like crazy as it drys and if a blank contains some of the dark heartwood, expect cracks. Can be white or have color.
Dogwood turns beautifully, though. This little finger top needed no sanding.
Makes me want to cut into the Boxwood now!
A friend who did ornamental turning often used Holly and some fine-grained tropical woods.
Currently working on cobbeling together a JaHo Ornamental turning device. With only 3 basic parts comprising it, it doesn't seem all that complicated. Looking for some bits of incidental information such as a good way to attach my chuck to the indexing head. I no longer own a metal lathe to making the little part is going to be an issue. Looking for some of the turners that have gone down this Rabbit hole concerning the Jaho to see if there are any good words of wisdom either good or bad in making one of these. Appreciate as many comments as possible since every bit of information will be helpful........thanks in advance
I had a good look at the JaHo before making my setup pictured above. Admittedly I already had an indexing plate and detent for my lathe. Fixing a wood turning chuck to a small rotary table was something that gave me pause. Also, while using a rotary table gives you lots of potential increments, I was concerned about “loosing my place” part way through the cutting process. Using an indexing plate seemed far less daunting.
I used a small but quite solid cast iron X Y table and I suspect it’s less likely to suffer from vibration than the extruded aluminium table used with the JaHo.
Good luck with your project. 😉
I built the JaHo and it is interesting to work with . Already had the cross slide vise. And the rest was not expensive.
View attachment 76261View attachment 76262View attachment 76263
Hi Bill.......YES, attaching the chuck to the rotary table is also giving me a BIG pause also. The original JaHo used high density plastic for this piece. The fellow from New Zealand machined it from steel but had a metal lathe. High density plastic is SUPER expensive in large sizes and then they want to sell you several feet of it. Back to the drawing board on this one. What did you finally use may I ask?
As you can see in the picture I posted earlier, my chuck is lathe mounted, so no need for an adapter.
I made an alloy mounting plate for the router but this could easily be made from wood.
This picture is a better overall view of my setup.
Bob, For mine I 3D printed a chuck adapter. I used 75% infil and PETG for the plastic. There are files for the chuck adapters freely available online from sites such as Thingiverse.
Thanks Colin, that's also where I'm heading. Found a fellow on Etsy that sells lathe chuck wall mount adapters. Sent him a drawing of what I need and he says he can 3D print me one up.
I printed up 1" X 8 and 1 1/4" X 8 chuck holders for my CNC machine and can now go from lathe right to CNC. And in reality from there I can go to my Rose Engine.
Keep in mind with 3d printing, it isn't infill that gives the most strength, it is the number of perimeters.
Can you explain this a bit more for us non technical folks please.
Perimeters is the number of times the outline will be followed on any particular layer. I am on my work computer, but I just pulled up the first 3d model that I had downloaded that illustrates the difference in perimeters:
Standard, 2 perimeters:
8 perimeters:
Those perimeters will serve to provide more strength, particular against external loads, than if you had 2 perimeters and then cranked up the infill percentage. That's not to say that adding infill doesn't provide strength, it is just you nowhere near as much as adding perimeters. It is a bang for the buck issue. Adding more infill has limits, so you increase print times and waste plastic when you would be better off adding perimeters.
Hi Bill, Believe I conjured up the solution to afixing the chuck to the Rotary Table. Used one of my Oneway Tailstock adaptors with some High Density Plastic and came up with this. Have not tried it out yet since I'm still waiting on delivery of my Cross Slide table......check it out.
That looks like a great solution
Hi Gerald.....my JaHo is nearing completion and I would love to see pictures of some of the work you've done with the unit. Would also like if you could share some information on the cutting tools used and the making of.
The only drawback on this jig is time it takes to complete. Tear out is sometime a problem but you can just turn that off and start over. My setup is a Sharpe cross slide vise. had to use spacers to get that at the proper cut height. I bought a Boring Head and that is in the headstock . I tried the cutters that came with the head but they are just not designed for wood. So I ordered a HSS rod and cut it to lengths. Tried several profiles and I do not remember which was best with least tear out. If you want to go deeper I would suggest to do it in steps. The vibration of the bar tends to loosen the rotary index and I tried several things before I eliminated that for the most part. Basically used a bolt on backstop for that. I would suggest starting with a plate for practice.The picture of the boring bar is before I ordered the rod.JaHo jig.JPG
Thanks Gerald......love the 5 ring pattern. Also like the "beefy" cross slide table you use. Is there a brand or model number. Have the feeling that the light weight "toy" I have ordered is just not going to be stable enough and I will in short order be looking for a better and more rigid one like you are using.....Good choice.
The only drawback on this jig is time it takes to complete. Tear out is sometime a problem but you can just turn that off and start over. My setup is a Sharpe cross slide vise. had to use spacers to get that at the proper cut height. I bought a Boring Head and that is in the headstock . I tried the cutters that came with the head but they are just not designed for wood. So I ordered a HSS rod and cut it to lengths. Tried several profiles and I do not remember which was best with least tear out. If you want to go deeper I would suggest to do it in steps. The vibration of the bar tends to loosen the rotary index and I tried several things before I eliminated that for the most part. Basically used a bolt on backstop for that. I would suggest starting with a plate for practice.The picture of the boring bar is before I ordered the rod.View attachment 81940
Gerald....just a note, but I've been searching all morning for the Sharpe cross slide vise you mentioned. Doesn't seem to exist anywhere. Do you recall where you purchased this. Love the solid cast iron table with this unit.
I haven't followed this thread carefully, but if you're looking for cross slide hardware you might check Little Machine Shop. I see several components that can be combined or assemblies that may be useful. Don't know the specs desired, but here is one assembly listed. (This one is well made and heavy duty.) I think they have others.
You can call them and talk to a knowledgeable person to see if they have something that will do what you want.
I bought a metal lathe, mill, and a bunch of tooling and accessories from them and have never been disappointed.
One thing I bought was a heavy duty precision rotary table, designed to be used on the mill, quite useful. For example, I mounted a vise on it and rotated it to the exact angles I needed to mill this logo for a branding iron:
A rotary table also makes it easy to lay out designs on turnings. For example, getting the spacing right for chip carving this goblet was trivial. I've used it for a bunch of things such as Christmas ornaments.
Was looking at your setup once again and re-read your comments. I was wondering what type of strange cutter you were useing......HA. I also just order some round HSS tool steel rod and will grind my own cutters. Square cutters are easy to come by......not so with round ones. I'm expecting them this Saturday. Also order a piece of Steel tubing for a base. Have to come up 59/64 and the tubing is 1" high. Will angle grind a bit off.
The cutter in the picture came with the boring head. I could not get any useful designs with supplied boring bits so like you have concluded I made my own in several designs
